Old 03-23-2019, 05:18 PM   #1
Hard to tell from pic, but usually vac lines like that require you to push the fitting together, pull a lip towards one end of the fitting, then pull the ends apart. Cant tell if this is the same type, but if so, it should come apart easily so dont go all he-man
Old 03-23-2019, 05:28 PM   #2
you may want to try putting some silicon at the hose joint and that may solve the issue without removing anything..
Old 03-23-2019, 06:11 PM   #3
jaykay's Avatar
Okay this is something I have not seen on Canadian/Euro cars. Can't tell you how that comes apart.
It must be a CA emissions or Tip thing.
986 00S
Old 03-23-2019, 06:55 PM   #4
More of a truck guy
I agree. I have some flex seal. I was going to cut a strip, and wrap around the junction. Easy enough to remove, if I have to dig back into it.
2002 Boxster S 6 Speed
TNT79Bronco is offline   Reply With Quote
Old 03-23-2019, 06:54 PM   #5
More of a truck guy
Yeah. I have made tools to do that in a couple of fittings. I have some where you have to remove a clip, and hold a “lip” forward, as you pull.
This one has nothing like that. I have tried pulling pretty hard, pushing in hard, and forcing apart, by inserting something between the two shoulders. Nothing.
