Old 02-25-2019, 07:51 AM   #1
Boxster window problem - help please
Hi all,
I'm hoping for some assistance - I have a 2001 Boxster s (now with a UK driver's side window problem).
Here are the facts:
Boxster garaged (dry) since October 2018
Two weeks ago started up (used power booster - jump start) and idled for ~ 30 mins (to burp, etc)
Yesterday started (used power booster - jump start) and idled for ~30 mins (pretty sure both windows worked)
Tried to restart without booster (drivers side window was down)
Car failed to turn over - got the unusual dashbord lights, etc
Drivers side window will not move at all
Passenger side window is fine - drops on roof opening, closes on roof closing
Pressing driver's side window switch I can hear either relay or solenoid type clicks in door
No screeching noise apparent (symptom of faulty regultor - I believe)
Started car with booster - no change with window
Disconnected battery and left for 5 mins (x2) reconnected and tried to move window - no change
Held window switch down (and up) for 10 secs - no change
Not sure what to next - trying to exhaust all avenues before taking the door card off
I think it's unlikey that the motor or regulator failed at that point in time - although it is a possibility
Fault appeared immediately after trying to start the car whilst not sufficiently charged (I thought 30 mins running and it would be ok)
Any advice on what else I could check will be gratefully received.
Flight643 is offline   Reply With Quote
