Old 01-15-2019, 07:31 AM   #1
Meyle Control Arms?
02 Base. Daily Driver. 160K. Front lower ball joints are shot. After reading a few threads on here, I have a few questions regarding Meyle Front Lower Control Arms:
1. In one thread people mentioned that The Meyle Arms were 6mm shorter than The Porsche ones. Is this really the case? If so, how can they possibly fit?
2. How well do these arms hold up? What sort of experiences have guys who have installed these encountered?
3. Is it really a get-what-you-pay-for situation with $100.00 Meyle Arms vs. $400.00 Porsche ones?
4. Does swapping the stock arms for Meyles affect the alignment? Will I need to realign the car after swapping out the arms for the non-clunking variety?
5. Can worn drop links add to the clunking? They are shot as well and I am looking at The TRW ones for replacements.
6. Should I do the inner & outer tie rods "while I am in there?" If so, then I definitely need an alignment, correct?
The clunking has got to go!
Thanks in advance for your help!
robdelorenzo is offline   Reply With Quote
Old 01-15-2019, 07:51 AM   #2
steved0x's Avatar
I've never seen that, is there a link? I am running these arms in the back and have had no problems with them, and they are the same length as the OEM Porsche LCA. The inner rubber bushing is about 1mm bigger in diameter and so you can't retrofit it with monoball cartridges, but the overall dimensions of the arms seem to be the same. I have one extra at home and can take some pictures next to an OEM porsche arm.
I like them, no trouble so far.
I don't think so, in my opinion Meyle makes good stuff, I would not hesitate to use any of their stuff.
In the back yes because the inner end that connects to the chassis is done using an eccentric bolt that sets the camber.
In the front, the ends of the arm are fixed and theoretically shouldn't affect the alignment, but if the old arm is worn and things are moving around, the new stiffer arm may change the camber slightly which would then change the toe.
I have heard yes although I personally haven't had that experience.
0
The tie rods aren't connected to the LCA (unlike for example the front "tuning fork" caster arm, so other than lifting the car and removing the wheels, there isn't much labor overlap. And yes a front alignment after replacing the tie rods.
Front clunking? I would suspect the tuning fork arm, in the back that one is notorious for clunking so maybe in the front too? If you are replacing the front LCA I would replace that arm too, Meyle makes that one too, Porsche cross reference 997 331 043 01, that is the rear tuning fork arm for 997, but also fits 996 all 4 corners and 986 Boxster front. That is one that is a good candidate to do while you are in there.
Old 01-15-2019, 07:54 AM   #3
Thank you steved0x.
This is what makes this place an invaluable resource!
Old 01-15-2019, 09:49 AM   #4
Artist, 986S tinkerer
NewArt's Avatar
And Steve, in particular, is a very generous fellow!
Old 01-15-2019, 09:57 AM   #5
steved0x's Avatar
You guys... I'm blushing I'm just paying it forward, I have soaked up so much knowledge from on here in the past so I'm sending it back!
Old 01-15-2019, 10:02 AM   #6
NewArt's Avatar
BTW Steve, your point-by article is getting a lot of traction here in my local Rennsport Facebook page! Thanks from all of us!
Old 01-15-2019, 12:22 PM   #7
On the slippery slope
JayG's Avatar
I have used a bunch of Meyle parts including rotors and master cylinder and they are high quality parts.
I would not hesitate to use them for any replacement parts
2004 996 Targa Tip
Instructor - San Diego region
Old 01-15-2019, 01:13 PM   #8
Clunking infront suspension
if you noticed the drop links has a tear on the ruber cover, you can replace them for less then hour on both sides and not that expensive. I’m sure it will lessen clunking sound or maybe no more clunking. I did that the 1st month a got my 99 boxster 103k mileage with newly installed LN IMS. Clunking went away after replacing my front drop links.
ndfrigi is offline   Reply With Quote
Old 01-15-2019, 01:40 PM   #9
You guys are awesome. Thanks.
Old 01-16-2019, 05:40 PM   #10
Just this summer I did tuning forks (track arms), outer tie rods, drop links (all four) and new front struts. You need an alignment for sure if you are doing the lower control arms. You also may as well do your drop links and tie rods. Better than paying for another alignment later.
I did front struts because I had heard the strut mounts can make noise. It ended up being cheaper to buy low mileage take offs than to buy parts and replace the mounts and dust boots. Not sure what all your noises are, but you may consider struts too. Another item that will require an alignment.
