Old 02-27-2019, 01:16 PM   #61
Ciao's Avatar
I installed mine today. I really like the look.
Pulled the trigger on these tail lights today. I've seen enough they are worth the upgrade on appearance and they support rear fog lights (stated in their website).
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 02-28-2019, 05:59 AM   #62
Thanks for organizing this. Just placed my order today.
thenavarro is offline   Reply With Quote
Old 03-04-2019, 10:09 AM   #63
The 12% off coupon code is "986forum".
No reason to try to be secretive about it.
Old 03-07-2019, 05:42 PM   #64
MN 986's Avatar
Just got mine yesterday and they look awesome on my black Boxster!
Fit and gaps/lines are pretty good, not quite OEM but close. One light has a little extra black sealant showing under the lens but not too noticeable. I'll adjust the fit a little when it's above freezing, and I cannot wait until the snow melts and I can get it out in the sun to really see them.
Here is a pic of the right unit installed.
MN 986 is offline   Reply With Quote
Old 03-07-2019, 06:01 PM   #65
Ciao's Avatar
They blend in well and look cool on your Black Porche
Old 03-07-2019, 06:28 PM   #66
Ciao's Avatar
My only concern is I was unaware that they are from Taiwan. Not sure they'll last as long as originals. Also wires are spliced--why?
Old 03-07-2019, 07:11 PM   #67
Multi-Boxer Driver
Deserion's Avatar
ROC > PRC
Spices should be fine if done correctly. Kind of looks like the "solder" spice connectors. Definitely want to see how they look on your Seal Gray.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 03-07-2019, 07:17 PM   #68
Ciao's Avatar
Originally Posted by Deserion View Post
ROC > PRC
Going on this weekend
Old 03-07-2019, 07:40 PM   #69
My guess... based on look of plug is pigtail was made too short and they extended. I'd give each wire a firm tug to ensure connected well. Then maybe a little heat to tighten up shrink tubing and add strain relief wraps of electrical tape, gaffer tape or zip tie bundle on both sides of the junction.
Speaking of plug BTW, I'd give that some love too and secure up a bit more w/ some black RTV sealant. If not using removable pin connectors as in an injection mold, that piece will be molded as one entire assembly with and the wires then cut to length at termination connector. Suspect they were initially. Then they realized overall pigtail too short. So they clipped all at plug to extend and then "hand molded" in the extensions back into original.
Looks sharp overall though and look forward to everyone reporting back LT results.
Good luck
"Cool Prius!"
- Nobody
Old 03-07-2019, 08:20 PM   #70
Got mine in tonight and got them installed in the dark in about 25 minutes of fumbling around with a small wrench and dropping two of the nuts and having to search for them in my junkie trunk.
Can't wait to see them in daylight but they look great from what I saw tonight. Makes the rear end look a lot more modern.
Didn't have a helper handy so I wasn't able to get any pics of them lit up but since it was night, I could see them light up and work properly from the reflection off of my other car parked behind it.
Very simple plug and play. I'm satisfied with the expenditure at this point.
Old 03-08-2019, 03:01 AM   #71
WillH's Avatar
I would like to see a smoke set on a black box if anyone has that combo.
Old 03-08-2019, 10:15 AM   #72
Ciao's Avatar
Good luck
BB,
I really appreciate your helpful tips and will use them. I'm disappointed in all the extra work needed to be done to ensure an EOM secure fit on new tail lights for the cost.
Old 03-08-2019, 10:35 AM   #73
That looks really nice! Is that a ducktail spoiler? Where did you get it?
phook is offline   Reply With Quote
Old 03-08-2019, 02:55 PM   #74
MN 986's Avatar
Thanks! I can't wait for spring and clear roads!
Yes, it is a ducktail spoiler made by forum member Joe Toth. Search and you will find a thread or 2. Very high quality, my paint shop was impressed, and easy to install. Highly recommended.
Old 03-08-2019, 06:11 PM   #75
Old 03-11-2019, 02:47 PM   #76
Boo
Boo's Avatar
Anyone have the new smoke tail lights on a black car?
I'd love to see those. Seems like a natural combo!
Boo is offline   Reply With Quote
Old 03-11-2019, 05:28 PM   #77
Ciao's Avatar
Installed 718 lights. They work fine, but a few shoddy details: too much wire, fit is not as close tolerance as OEM, no clip like OEM to clip excess wiring so wires are too lose, clip incorrectly labeled R was Left and L was Right, made in Taiwan...but from the outside they look nice and are functional. Wouldn't pay this price if I'd known about the shoddy details.
Old 03-12-2019, 10:39 AM   #78
WALDMEISTER
BRAN's Avatar
Has anyone figured out, how (or if) the fog light is working?
BRAN is online now   Reply With Quote
Old 03-12-2019, 01:09 PM   #79
Ciao's Avatar
Rear fogs work, in principal. They don't light up as much as the factory fogs.
Old 03-12-2019, 01:39 PM   #80
WALDMEISTER
BRAN's Avatar
Ah ok, good to hear. Any chance to take a photo, maybe?
