Old 12-09-2018, 11:32 PM   #1
Avoid Copy Window Regs
Hi Chaps
Iv learned this important lesson in the week just gone.
All started when my driver side window regulator decided to snap. I bought a brand new copy one off ebay for £79.99 delivered. Which I thought was a good deal.
Dropped the car off at my mechanic as arranged then went back 2 hours later..... he looked like he was going to cry. No matter what he did the window would not operate properly.
He informed me that windows with no upper frames need genuine window regulators or they will never work properly.
Solution: I bought one off a breaker for £101 delivered including the motor. Same mechanic had it fitted and working perfectly in about 35 mins.
has anyone else found this too?
YellowS2000 is offline   Reply With Quote
Old 12-10-2018, 07:14 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
I tried URO's and had one fail in less than a year. The other side was misshapen and the motor would not fit into the holes. I learned my lesson and put proper Porsche regs in and have not been disappointed. There pricey but I believe worth it.
Old 12-10-2018, 07:23 PM   #3
For a bit of counter information, I installed a URO one about a year ago and it has been perfect. However, it has not really been enough time to truly tell.
speedyspaghetti is offline   Reply With Quote
Old 12-10-2018, 07:48 PM   #4
rexcramer's Avatar
One of the cable pulleys just broke in half for unknown reasons. I got a full refund. The other appeared to be a bad mold/alignment issue. I took it back, with the motor, and tried two more that all had the same issue.
I really liked the idea of the bearing on the pulley design with the URO part. The OEM pulleys are just bushings.
In URO's defense, they stood behind products and refunded 100%. All I was out was gas and my labor.
Old 12-11-2018, 04:05 AM   #5
I have a twist to this story. My drivers side window would not rise and drop enough when the door opened and closed. I got into this forum and searched and it came back that if I could push the window down it is the regulator and I need a new one. Well I took this forum at its word and changed out the regulator, first with aftermarket, and when the problem was not fixed I installed a repair kit, and when that did not work ....
To make a long story short I changed the regulator four times. I could open up my door panel blindfolded. Finally I installed a used OEM regulator with a used OEM motor and the window works like new. Turns out my problem was the motor not the regulator.
obthomas is offline   Reply With Quote
Old 12-13-2018, 11:02 PM   #6
Hi Thomas
I had this problem too on the same side last year, but the window still operated. Took it to my tamed mechanic and he worked out it was the door lock that was goosed as it was not triggering the micro switch that lowers the window when the handle is lifted
I bought a new new lock... Porsche wanted £187. I got one from a breaker for £35 mechanic fitted it for £25.
Old 12-14-2018, 12:36 AM   #7
Oggie's Avatar
I've had a URO premium regulator in my '99 Boxster for over 18 months and it has worked faultlessly.
'99 base Boxster (Arena Red Metallic/Savanna Beige)
'02 911 Carerra Cabriolet (Arctic Silver/Metropole Blue)
Oggie is offline   Reply With Quote
