Old 11-14-2018, 07:23 AM   #1
The Radium King's Avatar
aos and oil fill hoses
hi - looking to replace the plastic accordion aos and oil fill hoses on my engine with something more robust. presume it has to hold vacuum and not collapse, handle engine temps, and be rated for oil and gas. would have to be flexible - probably more flexible than heater hose. anyone have a spec they could recommend? i went to the local parts store and got blank looks.
Old 11-14-2018, 07:41 AM   #2
New OEM parts are pretty robust. The heat cycling is what makes the parts in your car brittle
Nedlands is offline   Reply With Quote
Old 11-14-2018, 08:27 AM   #3
Who's askin'?
maytag's Avatar
Silicone hoses are probably the ticket. Based on the criteria you are describing.
Old 11-14-2018, 11:48 AM   #4
Radium,
Please note that the accordion hoses have a funky style connectors at the end, perhaps may be better to install a OEM hoses and forget about them for a few years..
Old 11-14-2018, 12:23 PM   #5
WillH's Avatar
New oem isn’t expensive. Not a fun job to replace the oil fill tube but not as bad as some make it out to be. Be sure to get the remote tool for the fittings.
