Old 09-10-2006, 02:47 PM   #1
Which gas to use?
My service manager recommended BP, Chevron, or Shell, for better performance from my Boxster. Something to do with additives that these companies add to the gas. BTW same recommendations from Audi service manager for my wife's new A4 Quattro!!! Anything to it?
tonyg is offline   Reply With Quote
Old 09-10-2006, 03:22 PM   #2
bmussatti
Guest
Posts: n/a
There are some great threads about this topic on the forum. Have you done any searches? There are some very knowledgeable members on the forum that know the ins & outs regarding this industry and their practices.
In general, the take-away that I gained was:
1) Use 93 octane if available in your area
2) Get the freshest gas possible from the busiest stations
3) Use a high quality fuel cleaner maybe once a year with Techron
Old 09-10-2006, 05:20 PM   #3
KevinH1990's Avatar
Most of the stations in this area began using a mixture that contains 10% ethanol about 5 months ago. There is one station near my work that does sell unblended gasoline - probably because it is in a rural county. So, I've avoided using the ethanol blend in my Boxster.
Until recently the unadulterated gas was cheaper than the blend. Now, the ethanol blend is 3-4 cents per gallon cheaper. Any opinions on whether I should continue to avoid ethanol? In my other cars, it seems that using ethanol results in lower gas mileage.
Old 09-10-2006, 07:41 PM   #4
Brucelee's Avatar
I can vouch for Chevron. Great gasoline.
Rich Belloff
Old 09-10-2006, 07:53 PM   #5
Send a message via MSN to CJ_Boxster
I live in Ca so all i have is 91 octane, i buy Cheveron, 76 or Mobile...Mobile seems to be the best when it comes to power and consistancey...cost more usually. I never ever use arco. Its the worst gas in the world (not counting Thrifty gas).
I sometimes use Techron Feul system cleaner...it really helps that full tank last alittle longer but then its back to normal when its all burned up.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 09-10-2006, 09:44 PM   #6
Hi,
Ethanol contains about 10% less energy/vol. than straight gasoline. This would account for the lowered MPG.
So far as it's compatibility, at these concentrations (10%) it won't cause any harm. Hope this helps...
Happy Motorig!... Jim'99
