Old 10-24-2018, 09:05 AM   #1
Windshield Chip Repair
I recently purchased my Boxster and it appears that the previous owner had repaired a chip in the windshield and before it had fully cured turned on the wipers. There is now a streak across the windshield that I have-not been able to clean. Any thoughts on how that can be removed? Solvent? Can it be buffed out?
Thanks!
bbiela is offline   Reply With Quote
Old 10-24-2018, 12:39 PM   #2
There Is No Substitute.
rick3000's Avatar
Have you tried using a razor blade? I would use some soapy water as a lubricant and see that takes it off, I would be very careful about using any heavy duty solvents near your paint, and buffing glass takes forever. Good luck!
Old 10-24-2018, 06:31 PM   #3
yes, I should have mentioned that was the first thing i tried and it had no effect.
Old 10-25-2018, 07:59 AM   #4
Maybe buffing it with a cerium oxide paste? See this thread.
Old 10-26-2018, 08:37 PM   #5
1997 Tip, 2018 Macan
rexcramer's Avatar
I have used Mothers Water Spot Remover and been very pleased with the outcome. A brand new single edge razor to shave the high spots followed with polishing compound should do the trick.
