Old 09-10-2018, 05:31 PM   #1
Damage from wheel spacers?
Hi all,
I got a 1999 Boxster and ordered 4 hubcentric wheel spacers, 15mm. Before I install them, any issues or potential damage from spacers?
Thank you!
CDNIcecube is offline   Reply With Quote
Old 09-10-2018, 06:43 PM   #2
Who's askin'?
maytag's Avatar
Originally Posted by CDNIcecube View Post
Hi all,
Thank you!
High quality, hubcentric spacers with appropriately longer lug bolts will cause no harm.
Many of us use spacers ranging from 10mm to 20mm. I personally have 13mm in the front and 20mm in the rear. I like the way it looks that way.
Old 09-10-2018, 08:51 PM   #3
njbray's Avatar
They should not cause any damage if put on correctly.
A good idea to put 5 of the standard wheel bolts in your car tool kit so you can use the spare wheel if necessary. The long bolts used with spacers may be too long.
Old 09-11-2018, 12:21 AM   #4
Carrying 5 regular bolts for potential spare tyre use - very good point - thanks for mentioning!
Never thought of that.
2003 Boxster S
Seal Grey
Bruich10 is offline   Reply With Quote
Old 09-11-2018, 01:44 AM   #5
WillH's Avatar
Or switch to studs.
Old 09-11-2018, 02:10 AM   #6
Excellent! Thank you all!
Old 09-11-2018, 05:44 AM   #7
Originally Posted by WillH View Post
Or switch to studs.
This is the way to go to me.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 09-11-2018, 06:40 AM   #8
jsceash's Avatar
17mm front spacer and 10mm rear spacer with 45mm stud kits from Rennline "0" problems on since 2012. Spacer as long as they fit tight to the hub center and give a lip on the outside that fits the wheel center they should not hurt anything.
http://www.rennline.com/Competition-Wheel-Stud-Conversion-Kit/productinfo/LS06/2197%7C2213
