Old 08-26-2018, 12:18 PM   #1
Schematic for 986 Cluster IC board?
Does one exist?
1998 Porsche Boxster - Ocean Jade Metallic
1985 Porsche Carrera Targa - Guards Red
1978 Porsche 911SC Euro Non-Sunroof - Grand Prix White
Seadweller is offline   Reply With Quote
Old 08-26-2018, 01:22 PM   #2
I've never been able to find one. Did you get your pin solder joints checked?
Old 08-26-2018, 04:25 PM   #3
I have never seen one or heard of one and expect that they are proprietary design information and thus, not available outside of Porsche.
Old 08-26-2018, 07:30 PM   #4
78F350's Avatar
I can send you a 2 MB .pdf - 3 pages you can print and lay together of this if it will be helpful:
I assumed you want the '98 version. PM me an email address if you want.
Old 08-26-2018, 08:07 PM   #5
I think he was asking for the circuit board schematic, not the wiring diagram.
Old 08-26-2018, 08:15 PM   #6
78F350's Avatar
Yes. Hence I offered what I have "if it will be helpful" and did not state that it was a circuit board schematic. Thank you for stating that in case anyone was confused
Old 08-28-2018, 09:52 AM   #7
Thanks guys...Yeah, the speedo shop that's looking at my cluster said he couldn't get one, but I thought maybe I'd get lucky on here. Evidently it's even more difficult to cross reference the parts even if he does identify the failure.
Particlewave, I checked everything from the battery to the pins on the connectors, including ground continuity, and everything was perfect. The speedo shop was able to confirm 100% that there's an issue within the cluster, as he duplicated the issue on his bench. He believes something is swapping between power and ground, causing the flashing.
78F350, thanks for the kind offer of the diagram. As mentioned, it's the diagram for the cluster IC board that I need. I guess Porsche would prefer folks to buy a new cluster at $2,600, 25% of the value of the car itself!!
Thanks everyone for the help! I'll let everyone know the outcome. Hopefully I can avoid buying a used cluster. I wonder if just the board itself is available somewhere?
Old 08-28-2018, 11:36 AM   #8
Might look at these sources https://sites.google.com/site/mikefocke2/listsofsources of used parts. IIRC may will have to have it coded by a dealer who knows what they are doing but the part should get you partially working.
I'd look for woody first. Reasonable, reliable and knowledgeable.
Old 08-28-2018, 11:40 AM   #9
I was thinking the same thing as it should allow you to swap clusters to ID the issue (at least isolate)..
Good luck!
Old 08-28-2018, 10:47 PM   #10
Don't have the wiring diagrams for the IC. Must be Bosch i think.
Smallblock454 is online now   Reply With Quote
