Old 08-17-2018, 09:14 AM   #1
More of a truck guy
Gap between window and convertible top '97
I am about to put a new top on my "$700 Boxster Project". It has been a fun project getting it back running. The rear plastic window is gone, and the top is shot. I just purchased a replacement top off of EBay, and will be installing it in a week or so.
However, I noticed that there is a gap on both sides of the car, where the window meets the seal for the convertible top.
I think this is what allowed water into the car, that fried the immobilizer (or maybe it was the missing rear window????). The window goes up and down as it should, when the door handle is pulled and released, AND....it seems to be making good contact at the top of the window. It is only toward the lower rear portion, that it seems to have a gap issue. Any ideas on what adjustments can be made?
2002 Boxster S 6 Speed
TNT79Bronco is offline   Reply With Quote
Old 08-17-2018, 09:31 AM   #2
A8ked's Avatar
There are several adjustments that can be made to the window regulator that affect the window fit. It looks like you just need to make some adjustments. Check out the Pelican Parts web site for instructions or do a web search.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
Old 08-17-2018, 03:34 PM   #3
Looks like the soft top is mounted just slightly aft of home position. The 3 main mounting bolts on Lft/Rt may need adjusting.
Lapister is offline   Reply With Quote
