Old 07-20-2018, 09:15 AM   #1
A8ked's Avatar
Sticking handbrake release button
The emergency/handbrake button in my 98 Boxster occasionally sticks in the depressed (in) position. It sometimes feels like there is some binding/scraping as the button is depressed. The button will eventually release if I press it a couple times or slap the handle. The Ebrake works fine and releases, the handle button just sticks and triggers the dash light. Anyone else encounter this issue and know what may need to be addressed?
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
Old 07-21-2018, 06:08 PM   #2
same thing on mine, i just give the handle a little flick and the button pops out. Sort of annoying but not enough for me to take apart the console area to remove the handle and fix. If someone has an easy suggestion i'm all ears as well!
dav9515 is offline   Reply With Quote
Old 07-22-2018, 01:25 AM   #3
Cunningr's Avatar
Mine too. Bad enough where my top got stuck open. I bought the switch, but waiting till off season to work on it. So I bought a smart top relay, resolved issue wwas expensive but was wanting one so just bought it.
Options keep top working is bend pin 15 on top relay and run a ground wire from socket I think it was or maybe it was solder to the relay pin and ground. If you search for cheap smart top mod or look on Pedro’s site there are instructions.
That bypasses the emergency brake switch.
Old 07-22-2018, 09:08 PM   #4
NWI Bill's Avatar
You can lubricate the handbrake linkage. The top cover lifts off on the handbrake exposing the cable and spring assembly. My 97 was doing the same thing and I used water proof silicon spray and that took care of it. That was a year and half ago and no issues or re-occurrence.
1999 996-Carrera Arena Red Metallic-Current
1998 Boxster-Glacier White-Sold
1997 Boxster-Ocean Blue Metallic-Modified-Sold
NWI Bill is offline   Reply With Quote
Old 07-23-2018, 08:46 AM   #5
A8ked's Avatar
Thumbs up
Thanks NWI Bill, I'll give your fix a try!
1998 Boxster
1991 Carrera
Old 08-13-2023, 06:23 AM   #6
I know this post is from a while ago but my 97 brake button is sticking from time to time. Can you describe what you mean by the "top cover"? I'm not sure what cover you're referring to. Thanks
Mick
mickster2000 is offline   Reply With Quote
