Old 07-18-2018, 11:27 AM   #1
Will there be cake?
tonythetiger's Avatar
Floor Mat Problems
The fastening plate for the floor mats won't stay in the carpet (part #98655198500)
This means my car mat doesn't stay in place. The dealership tells me that the fastening plate screws into a holder under the carpet, but after lifting the carpet, I cannot find anything to screw it into. The other plate doesn't screw into anything and appears to just hold in the carpet
Am I missing something?
Old 07-18-2018, 11:42 AM   #2
Lew
So Blessed!
Lew's Avatar
This means my car mat doesn't stay in place. The dealership tells me that the fastening plate screws into a holder under the carpet, but after lifting the carpet, I cannot find anything to screw it into. The other plates doesn't screw into anything and appears to just hold in the carpet
Since your floor mats has a Velcro area on the bottom of the floor mats. Maybe measure from the side of the floor mats to the Velcro area and line that measurement up under the carpet. Maybe that will help locate the spot you are to use. I don't have the fastening plates you mention. I installed custom floor matts.
My New Floor Mats
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
Old 07-18-2018, 12:17 PM   #3
The fastening plate has a screw molded into the backside which screws into the carpet.
I'm sure you can find them cheaper but here's where you can buy replacements as it sounds like the screw has broken off yours.:
https://www.ecstuning.com/b-genuine-porsche-parts/floor-mat-fastening-plate-priced-each/98655198500/
BMWs of recent era also use them and they are approximately the same size so they can be interchanged and/or found on fleabay:
https://www.ebay.com/itm/BRAND-NEW-BMW-GENUINE-OEM-FLOOR-MAT-HOLDER-VELCRO-LOCK-18F10-FREE-SHIPPING/132697065839?epid=5020510932&hash=item1ee55c896f%3Ag%3ANzAAAOSwjzJbJ5rn&_sacat=0&_nkw=bmw+velcro+mat+tab&_from=R40&rt=nc&_trksid=m570.l1313
Good luck
"Cool Prius!"
- Nobody
Old 07-18-2018, 12:22 PM   #4
Will there be cake?
Good luck
OK, the screw isn't broken off, also, I have a new one. The screw is there, the hole in the carpet doesn't hold the plate...think like a stripped out screw hole in wood or something. If there isn't something that this plate screws into besides the carpet (the hole is worn out and doesn't hold the fastening plate) then I have to figure something out.
Old 07-18-2018, 03:37 PM   #5
WillH's Avatar
This^^^
Mine is the same. Thought about ditching the carpet...
Old 07-19-2018, 04:47 AM   #6
Easy fix...
Move 'plate' to a different location. Then get some new adhesive backed 'loop' velcro and w/ a few extra dabs of super glue, place a patch large enough to back of mat in corresponding location. I had to do similar w/ the Lloyds mats in my 997 (their clips, which hook onto the seat frame rails, did not fit/work).
Good luck
"Cool Prius!"
- Nobody
Old 07-22-2018, 08:22 AM   #7
WillH's Avatar
Thanks, first time in recent memory that I didn’t have to pull the carpet back into its place after getting in 👍🏻
