Old 07-04-2018, 09:12 AM   #1
Goth Popper
99 Boxcutter's Avatar
Boxster S Battery dead, cannot open the trunk
My battery is dead in my 2001 Boxster S and I don't know what to do because the hood release is electronic and the cable under the wheel well isn't there and it's about to rain.
www.appleneworleans.com
99 Boxcutter is offline   Reply With Quote
Old 07-04-2018, 09:21 AM   #2
Do you have the red pull out tab in the fuse box?
Let this be a lesson: find and move the emergency release cable to an accessible location.
Old 07-04-2018, 09:49 AM   #3
Goth Popper
I have the red tab. I connected duracell jump box and it didn't work, it just sounded the alarm and drained my jump box https://www.duracellpower.com/products/lithium-ion-jump-starter
I need the exact location of the pull cable.
Old 07-04-2018, 10:20 AM   #4
BirdDog's Avatar
Originally Posted by 99 Boxcutter View Post
I'm not seeing any red tab.
I own one of these, can I connect a speaker wire from the hot to one of the fuses?
That should work. Watch this video to see how to do it:
https://www.youtube.com/watch?v=ss6-8TJYIqE
Screen shot of the hook up from the video (it's from the owners manual):
(sorry for the low-res)
Basically, hook your red battery clip to the red terminal in the fuse panel and clip the black battery clip to the drivers door hinge. Attach the red first, then the black. Then use the hood release switch (or the button on your keyfob) to open the hood. Disconnect the black clip first, then the red.
Old 07-04-2018, 10:21 AM   #5
this will work. Ground it and find a place to insert power.....
Third row down from the top and three fuses in from the right side of the fuse box is a 30 amp fuse marked 30.
study the wiring diagram and fuse box OR GO HERE FOR a video from a brit on how to do it: https://www.youtube.com/watch?v=u0EpWBV3be4
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
Old 07-04-2018, 10:26 AM   #6
DrCactus's Avatar
I own a 2001 S myself and the red tab does not work on my car... check in the passenger side rad (corner bumper) and see if you see a silver cable loop sticking through. Pull this cable hard and the front trunk will open (manual hood release).
DrCactus
Old 07-04-2018, 05:06 PM   #7
Goth Popper
OK, i have the red pull thing in my fuse box. Am I supposed to connect power to it or pull it really hard?
Old 07-04-2018, 05:13 PM   #8
Connect power to it and the ground to the body (door striker).
Old 07-04-2018, 05:22 PM   #9
Goth Popper
No need to take off the wheel, just put my arm through?
Old 07-04-2018, 05:34 PM   #10
Several options I've collected over the years https://sites.google.com/site/mikefocke2/whenyourbatteryisdead
Old 07-04-2018, 05:46 PM   #11
Goth Popper
DrCactus I need more clarification. I know where the release is on a Boxster Base, but I can't find it on my S. Is it in the wheel well?
Old 07-04-2018, 05:58 PM   #12
Goth Popper
I did all that stuff. The horn beeps and everything, but the hood won't pop. I need to know the exact location of the pull loop.
Old 07-04-2018, 05:59 PM   #13
Goth Popper
I don't know which is more dead, my battery or Radio Shack?
Old 07-04-2018, 06:21 PM   #14
Some people redirect the wire some other place.
I can pull my headlight out without tools. That's where it is.
If yours has never been relocated it, you will need to take the passenger side wheel off to access it.
Fuzzuki is offline   Reply With Quote
Old 07-04-2018, 08:16 PM   #15
Pdwight's Avatar
Another method
My fuse box connection would not work for me when my battery died for some reason. I used a phillips screwdriver with tape around the shaft except the point, connected the ground at the door jamb and the positive on the phillips and touched it to the inside connection point on the lighter.....instantly the lights came in the dash and I hit trunk open and it popped open. I then disconnected everything and got a new battery.
Old 07-04-2018, 10:32 PM   #16
Mig
When my battery died, I put power from another vehicle to the cigarette lighter. You can get enough power through the cigarette lighter to deactivate the hood locking mechanism.
I used the cords that came with my trickle charger to get power to the cigarette lighter. My trickle charger came with three cords: cigarette lighter, alligator clips, and ring terminals.
I simply connected the alligator clip harmess to the cigarette lighter harmess enabling me to connct regular jumper cables.
NOTE: the polarity will be reversed so make sure to connect your battery correctly.
It may sound crazy, but you can hook up jumper cables to a cigarette lighter and not damage your car.
I now carry this little harnes with me at all times. Just in case...
Mig is offline   Reply With Quote
Old 07-05-2018, 04:13 AM   #17
Multi-Boxer Driver
Deserion's Avatar
I used the posted method from the manual (with my digital battery charge) to pop the frunk on my mother's '06 987 when the battery was flat. However, I had to have it powered on for a minute or so, it wasn't immediate.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 07-05-2018, 01:29 PM   #18
Porsche9's Avatar
I just used the fuse box connection and it worked fine. Now for the idiot that left the interior light on.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 07-07-2018, 03:51 PM   #19
Goth Popper
How is it possible to remove the headlight without tools? :dance:
Old 07-07-2018, 03:56 PM   #20
Goth Popper
Yeah, I suspect my fuse is blown. Anyone know what number it is?
