Old 06-22-2018, 02:42 AM   #1
air conditioning problem
Friends I have an air conditioning problem. Recently refilled and already lost all the gas. What can be verified? are there any known problems? exists diy tutorial? Thanks in advance
Hi, i'm Antonio from Italy.
Boxter 986 S Year: 1999
alcubot is offline   Reply With Quote
Old 06-22-2018, 03:33 AM   #2
Multi-Boxer Driver
Deserion's Avatar
A leak that quick would point me to the condensers. That's the most likely spot for a puncture in the system due to road debris.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 06-22-2018, 04:19 AM   #3
edc
550 Anniversary
edc's Avatar
Use a dye in the system and check for leaks as above. Condenser is a cheap and easy fix. The front to rear pipe can corrode especially by the clips or get crushed or punctured by a stray jack.
Old 06-22-2018, 07:35 AM   #4
1998 Boxster Silver/Red
Recently I read, somewhere, that introducing a chemical into the system can create more problems than it reveals.
Hoping a PRO will chime in and tell me I'm incorrect.
1998 Porsche Boxster
Old 06-22-2018, 09:57 AM   #5
Shops use dye in leaking systems all the time. Trick is to use a dye made for the purpose, which will not harm anything and can be left in the system indefinitely.
Old 06-22-2018, 01:46 PM   #6
If you know for a fact that there is no more freon in the system (don't vent freon into the atmosphere!) rig up dry shop air into the system, m80-90 psi will do, and listen for a leak or check with soapy water. I found the leak in my 986 within 10 seconds that way (corroded low pressure line underneath car).
RodJ is offline   Reply With Quote
Old 06-22-2018, 07:40 PM   #7
1997 Tip, 2018 Macan
rexcramer's Avatar
I would like to suggest that you use nitrogen, instead of shop air if at all possible, for the purpose of pressure testing.
