Old 06-12-2018, 02:32 PM   #41
Originally Posted by tonythetiger View Post
Team,
What are the widest spacers I can put on a stock 986 S without rubbing. I was thinking 20mm front, 15 rear, but I want to use stock bolts for the wheel and thought I'd ask who sells a complete kit. Advice on width and sourcing would be appreciated.
I have the 18" wheels.
I would not use regular spacers and longer bolts for 20mm or wider. You can get hub centric spacers that use your stock bolts with lugs and nuts to attach your wheels. They aren’t cheap, but shouldn’t wear out your wheel bearings so fast.
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
Old 06-12-2018, 02:57 PM   #42
Cunningr's Avatar
I believe porsche recommends using equal spacing front and rear. I could be incorrect though, just remember a thread with that mentioned.
Old 06-12-2018, 05:19 PM   #43
1998 Boxster Silver/Red
Originally Posted by A8ked View Post
Read again carefully I said no rubbing.
No ****************, Dick Tracy. All this talk about rubbing, and you've got inches. I could fit 6 of my dicks in there.
My question was general in that you've a ****************ing grand canyon between your wheels and the lip. Who in their right ****************ing mind would not see that and still ask about rubbing? Or even mention the absence of it. Am I ****************ing missing something here?
Please read carefully? I read for a ****************ing living.**************** off.
You're from Seattle? I'm sorry. I'll try to speak slower next time.
Have a nice day.
1998 Porsche Boxster
Last edited by Starter986; 06-12-2018 at 05:23 PM. Reason: I don't need no steeeenking reason.
Old 06-12-2018, 05:48 PM   #44
A8ked's Avatar
Yes, you are missing something, I was simply responding to the question from "ShortRound " as to if there was any rubbing. Perhaps you should be venting your frustration to "ShortRound" he asked the question.
Sorry, I did not intend to question your intelligence or manhood.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
Old 06-12-2018, 06:01 PM   #45
Thank you for pointing that out. Please accept my apology.
Yeah... Shortround. WTH.
No apology necessary, thank you and, again, my apology for the comment.
Clearly I wasn't bragging about girth. Fitting in 6 dicks wouldn't be fitting, no pun intended, for a well endowed man. Maybe I should have said 1 dick.
Old 06-12-2018, 09:48 PM   #46
Cunningr's Avatar
Well A8 certainly has no dick room with the 20mm spacers in! Hahaha maybe a finger
Old 06-13-2018, 04:49 AM   #47
via GIPHY
X
ShortRound is offline   Reply With Quote
Old 06-13-2018, 05:09 AM   #48
Cunningr's Avatar
Well have my 15mm spacers and lug bolts on hand now. Hopefully, get them installed Saturday.
