Old 04-13-2018, 12:58 PM   #1
Zzorro's Avatar
986 Drip Pans - Repair or Replace?
Brining a 986 back to life. Has holes in the drip trays. Water leaked. CLU damaged. You've all read the posts.
Good news is the car starts, runs and drives great!
Convertible top is off, drip trays are removed. Interior completely ripped out and it's drying out. The top is also converted to manual with all arms and pushrods removed etc.
New Porsche OEM replacement drip trays are $225 each side here in Vancouver area of BC. So I'd like to see what options are out there first. So here are my questions/thoughts.
Who has had success in repairing holes in these drip trays? I have seen a few posts about silicone sealing the holes. For those that have done it; has is worked out and held up?
Has anyone had success with adding a layer of waterproof material to the underside of the entire tray? I'm thinking like a heavy plastic membrane under the whole thing and spray gluing it to fuse it together?
Does the 987 drip pan fit a 986? It looks to be made of a more durable molded plastic as opposed to thin/flexible foam. Anyone tried it?
I've looked into used ones and think it's a crapchute. But will consider buying a pair if anyone has some good ones to sell me.
Thanks you boxster brainiacs for having a read and responding. I can't wait to teach my daughter how to drive in it once it's all fixed up. You guys have helped me get lots done on my refurbishment so far.
Zzorro is offline   Reply With Quote
Old 04-13-2018, 04:06 PM   #2
Rich
I have no experience with this. Ok with that warning out of the way...you might try placing roof underlayment for ice dams. It is water proof and will stick to it self. Here is the GAF style https://www.lowes.com/pd/GAF-WEATHERWATCH-36-in-x-50-ft-150-sq-ft-Polypropylene-Roof-Underlayment/50353096
Rich XTR is offline   Reply With Quote
Old 04-13-2018, 05:36 PM   #3
Zzorro's Avatar
Great idea!
Old 04-13-2018, 06:40 PM   #4
First off, can you control the weather conditions your car will see? What I mean is that my car is garage kept. It does see rain and will occasionally sit outside with the top off. i keep my drains clean but have been surprised by what I've found in the tray!
If your car isn't sitting outside all the time, you might try to repair your trays and test them prior to installing. Even Plastidip may work. Risk/reward is up to you but I'd sure try something before forking out $450 for two trays.
BTW, I did repair a tray on a 1998 I owned for a bit. I used black RTV and it worked great. No idea how long it would hold but I sold the car to a buddy and we're still friends!
Old 04-13-2018, 07:46 PM   #5
Zzorro's Avatar
Thanks for the response. Good to hear the RTV sealant worked and always nice to maintain friendships! And plastidip? Hmmmm. Interesting idea.
To answer the first question: the car will reside outside unfortunately. I can commit to keeping the drains clean for sure though!
Wonder if anyone has ever made a silicone molded replica of one of these. That would be way more durable than these foam pieces.
Old 04-13-2018, 08:23 PM   #6
jsceash's Avatar
Mine have been removed for weight reduction. Sealed under the air duct with a little spray in foam. Removed the drain piece. Drilled an extra hole in the bottom of the tray base.
They are pretty much destroyed while removing them so I doubt you will find any used ones.
Old 04-14-2018, 02:06 AM   #7
BirdDog's Avatar
You might try this for the right side...
https://www.ebay.com/itm/Porsche-986-Boxster-97-04-Convertible-Top-Water-Drip-Liner-Pan-Right-Passenger-/151850238416?_trksid=p2385738.m4383.l4275.c10
And here's the left side:
https://www.ebay.com/itm/Porsche-986-Boxster-97-04-Convertible-Top-Water-Drip-Liner-Pan-Left-Driver/151850238415?hash=item235afac1cf:g:QPsAAOSwr81UUS6 5
Both look to be in good condition, and for $29.99 each they sound like a steal...
Note: I haven't dealt with this ebay seller...
Old 04-14-2018, 06:35 AM   #8
KevinH1990's Avatar
There may be some that survive removal.
I needed to replace mine after I gouged them during a top and frame swap. I managed to find a nice pair from a recycler. I was buying some other parts and the company just threw them in for free.
Contact Woody (Itsnotanova) in the parts sale section and see whether he can help. Send him a text - he will respond more quickly.
Good luck
Old 04-14-2018, 06:36 AM   #9
Zzorro's Avatar
I think they come out pretty easy. I took mine out carefully and I didn't wreck them (anymore that they already were anyways).
It's been said before, but what a horribly inadequate materials for such a critical job!
Old 04-14-2018, 06:37 AM   #10
Zzorro's Avatar
Good luck
Thanks! I'll try Woody now.
Old 04-14-2018, 06:43 AM   #11
Zzorro's Avatar
BirdDog, thanks for the eBay links. Have contacted the seller to confirm they will combine shipping to Canada.
My experience with the exchange rate, shipping and handling fees and duties has not been great. $100 USD Pelican parts order shipped via USPS to me was $170 by the time all was said and done. I miss the days of dollar parity!
Still a lower price than buying new. Let's see what the seller says.
Again. Thanks.
Old 04-14-2018, 07:14 AM   #12
Have you searched for Euro Wrecking Yards in the Vancouver area? There's a place called Alpi's in Surrey
2001 Boxster
2007 Toyota Highlander
Old 04-14-2018, 07:18 AM   #13
Zzorro's Avatar
My last dealing with Alpi's was not great. Wanted a premium for the parts. Made more sense to buy new. That's was years ago in my jetta/golf days. I'll reach out again. See what they say. Thanks.
Old 04-16-2018, 06:37 PM   #14
Zzorro's Avatar
Update:
Ordered up some used drip pans from Woody. Expect them to be in excellent shape just like his communication.
I liked Rich XTR's idea a lot though and may consider doing something like that as well.
Thanks all for the response. Much appreciated.
