Old 04-10-2018, 05:10 PM   #1
Sealant on water pump gasket?
I’ve seen posts both ways. Install dry or with sealant. If with sealant what type? Seal the bolt threads? Do the bolts hit water?
Thanks.
Doug427 is offline   Reply With Quote
Old 04-10-2018, 05:17 PM   #2
1998 Boxster Silver/Red
Thanks.
No sealant. Properly torque. Lots of great threads on the WP install.
1998 Porsche Boxster
Old 04-10-2018, 05:49 PM   #3
steved0x's Avatar
The bolts hit no water, and no sealant for me, but I did buy an oem style metal gasket, possibly Porsche brand.
Old 04-10-2018, 05:54 PM   #4
BirdDog's Avatar
Thanks.
No, no, no! No sealant! Just torque to proper spec (8 ft-lbs I think, but double check me on that) with a new (metal) gasket. If your water pump is original, you'll have to cut the old gasket to remove it. New gasket will also have a section you'll need to remove.
I have no advice about bolt thread sealer. I didn't use it when I installed mine. I don't remember the bolts seeing water...
Hope this helps...
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 04-10-2018, 08:55 PM   #5
Thanks, all. I have a metal gasket, so I guess I'm good to go.
Old 04-11-2018, 09:40 PM   #6
On my 928 I used Permatex high temp (copper in colour). Bone dry after 10k so I'm very happy
Porsche-Eh is offline   Reply With Quote
Old 04-13-2018, 06:09 PM   #7
rp17's Avatar
Hey Doug what did you use to get those tricky right bolts on the water pump? Frankenstein wrench? Or does the swivel socket approach work?
Old 04-13-2018, 08:24 PM   #8
I took the right side bolts off from under the car using a 1/4" drive ratchet, a long extension and a 10mm flex socket. It was an easy job, start to finish at a very relaxed pace less than 2 hours, most of that time was spent draining and adding back the coolant. The actual swap of the pump, from first water pump mounting bolt loosened to last water pump mounting bolt tightened, was probably 20 minutes. The rest of the time was all removing panels, hoses coolant, fan belt, etc. really, nothing to tough about it at all. I bought a 1/4" drive inch lb. torque wrench to get all the bolts torqued properly. It's on the car now, no leaks.
