Old 04-08-2018, 04:15 AM   #1
QUICK SANITY CHECK NEEDED: speaker install!
I have a blown-out door speaker and I bought replacements: Alpine SPR-50C (https://www.alpine-usa.com/index.php/product/view/spr-50c/)
So my question is: can I simply replace the door speakers with the Alpine SPR-50C 5 1/4" speakers as drop-in replacements? (I.e. not having to worry about installing the tweeters and crossovers included in the SPR-50C package?)
I currently have the M490 6x40 996 Cabrio Amp installed and Alpine SPG-10c2s in the dash.
Thank you for any and all guidance!
square-root is offline   Reply With Quote
Old 04-08-2018, 06:18 AM   #2
morgal48's Avatar
With the Haes amp you will not get much out of your new speakers. The 6X40 has an internal low pass filter, so nothing but bass will be sent to the doors. Having been where you are, I found limited choices:
Replace the Haes amp and use any speakers that will fit the doors
Modify the Haes amp
Buy replacement factory speakers and keep the amp
Replace both the amp and speakers
My choice was a new amp and replacement factory door speakers. My ears are tin, but I have been surprised at the level and quality of sound from those 5-1/4" subs. And the fronts and rears (the paper cones in those died and were replaced long ago).
There a several posts here about the options - make sure those Alpines are shallow enough to fit.
Good luck
2000 Boxster S
2010 Volvo XC60
2011 GMC Denali HD 6.6L (sold)
2008 Cayenne S (sold)
1989 Targa (sold)
morgal48 is offline   Reply With Quote
Old 04-08-2018, 06:43 AM   #3
Modify the Haes amp
Good luck
Soooo, can I install the speakers as replacements for the door speakers as-is without adding the crossovers and/or tweeters?
Old 04-08-2018, 10:31 AM   #4
Boxing Cat's Avatar
If you are just installing the 5 1/4's mid/bass drivers - sounds like the answer is yes.
Boxing Cat is offline   Reply With Quote
Old 04-08-2018, 12:43 PM   #5
Cunningr's Avatar
Should be able to, bolt them in, thing is those are actully subwoofers not mids.
i am doing 6.5 inch. In doors I changed the dash speakers and head unit this weekend and what a difference. Tweeters were a pain, for the dash i used the cai adaptor. I have a subwoofer from 996 going to modified to hold sn 8” pioneer sub.
Just off the changes i did i would have been happy cant wait to finish install.
Old 04-08-2018, 05:53 PM   #6
morgal48's Avatar
Yes. Chances are they will sound like the ones you are removing. The factory door speakers are 2 ohm, and if your new speakers have a higher impedance you will actually hear less sound than you do now, which I know is just not much.
I am NOT an expert, but did a lot of research on this site, and auto electronics sites before any changes were made. Many others have done as Cunningr, but that requires removing door panels and fashioning a replacement support system for the new speakers. A template for the support design is available on Rennlist, I think.
Again, good luck. Its all fun, especially when you finish and what you did works!
2000 Boxster S
2010 Volvo XC60
1989 Targa (sold)
Old 04-08-2018, 09:34 PM   #7
Cunningr's Avatar
If you go my route and go bigger, i suggest buying new door speaker boxes to modify. I used the nokia, but knowing more info now I suggest using the bose style enclosure as it has more volume.
Old 04-09-2018, 12:33 PM   #8
Thanks all!
Since the right door speaker is already blown out / desintegrated, installing the SPR-50C will definitely be an upgrade
