Old 03-30-2018, 05:49 PM   #1
Different Hydraulic line than standard for Slave Cylinder???
Hello, I am currently replacing my clutch slave cylinder. When trying to remove the hydraulic line, I noticed it is not the same one I have seen in the 101projects books or anywhere else online where you can just pull the metal pin and pop the line out of the cylinder. I have found one other post about it, but I am still unsure what to do. I will copy that link.
Clutch slave cylinder install
I have attached pictures if anyone else can help!
drewmarc is offline   Reply With Quote
Tags
maintenance , slave cylinder
