Old 03-20-2018, 07:38 AM   #1
Non-Porsche anti freeze/coolant
Have any of you used a non Porsche antifreeze/coolant? If going non Porsche, what is commonly used? I can get Zerex and Prestone products around here. Not sure which type of each brand is used in a Porsche. Thanks.
Doug427 is offline   Reply With Quote
Old 03-20-2018, 09:17 AM   #2
kk2002s's Avatar
Because mixing types (Not up on the exact different types) of coolant can cause serious issues. if you currently have Porsche Antifreeze, you would need to flush it out completely before replacing it. I flushed mine twice before refilling with Porsche coolant from Porsche coolant. I'm not sure I flushed out all of the old. I think you would have to pull the hoses off the radiators and make sure they were drained
Seal Grey
Old 03-20-2018, 10:45 AM   #3
Prestone Dexxcool will do. Very compatible and won't cause problems. A good flush would be nice, distilled water of course. It's OAT based and doesn't contain silicates.
2001 Boxster
2007 Toyota Highlander
Old 03-20-2018, 10:45 AM   #4
Doug427,
When I replaced my two radiators on my 99 Boxster, I used VW antifreeze.
It is the exact same stuff that comes in the Porsche jug, it just doesn't have the Porsche mark up.
MNC-I
mnc-i is offline   Reply With Quote
Old 03-20-2018, 10:56 AM   #5
Multi-Boxer Driver
Deserion's Avatar
It's like an oil thread, many different thoughts on what to use.
I went with Zerex G-05 when I did my water pump as that's the MB-spec stuff I used in my E320. When I do a flush next it'll likely be Pentosin G12.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 03-20-2018, 12:02 PM   #6
SC-986's Avatar
Pentosin Pentofrost ++ here.
2002 Boxster base - Seal Grey, 5spd trans.,ROW M030 upgrade, FVD Brombacher software tune
2004 550 Spyder Anniversary Edition, #1541,Tip, TechnoFix DOF IMSB upgrade
SC-986 is offline   Reply With Quote
Old 03-20-2018, 12:32 PM   #7
Porsche9's Avatar
What, something beside Porsche Unicorn derived coolant can be used?
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 03-20-2018, 12:42 PM   #8
still plays with cars...
BoxsterSteve's Avatar
Originally Posted by mnc-i View Post
Doug427,
MNC-I
+1 on the G12 or G13 VW coolant.
I used it a couple of years back when I did the water pump and Tstat.
The world hasn’t ended yet.
Six speed 2000 Boxster S
Old 03-20-2018, 03:53 PM   #9
Just to keep it consistent with NO question, Porsche blood for me. Learned this lesson the hard way in my Jeep...
Old 03-20-2018, 04:20 PM   #10
I unfortunately have oil in the coolant, likely (I hope) due to a faulty oil cooler or o-ring. It's be flushed super thoroughly, so no real chance of contamination with the new coolant. It just irks me the ridiculous price that Porsche charges for simple coolant. Simple DexCool, if it works, is inexpensive and available. I really can't see any reason it won't be just fine. I also noticed that in his water pump replacement how-to (or maybe it was his cooling system flush how-to writeup), Pedro, who has forgotten more about Porsche's than I will likely ever know, used plain 'ol green Prestone. Thanks to all of you for the answers.
Old 03-20-2018, 05:21 PM   #11
SC-986's Avatar
Years ago I worked in a GM service lane and saw quite a few vehicles come in where the Dex-Cool gelled up and created all kind of cooling system issues. Simply anecdotal evidence but unless they've re-formulated the product that would be the last coolant I would consider.
Old 03-20-2018, 06:50 PM   #12
This is because Dexcool (aka Deathcool) was originally introduced without proper validation with all components for compatibility, killing elastomeric seals, gaskets, etc.
With above said, it works fine when the entire system is properly designed and validated for. Actually I use it exclusively with my 03 SAAB and no compatibility issues for 175K mikes and counting.
With my 986, I’m sticking with original Porsche coolant. Pricey but I did complete drain and refill shortly after my purchase 12K miles ago and I do not plan on changing it for at least 5 years so no big deal.
Old 03-20-2018, 06:51 PM   #13
I didnt hit up the dealership. I just bought stuff that was for Porsche, vw, Audi and a few other euro makes. The brand I got also makes stuff specific to Japanese and North American cars and list brand compatibility
986bsdriver is offline   Reply With Quote
Old 03-20-2018, 07:35 PM   #14
Back when I had my Bimmer I used to use the gold colored Zerex G-05. Maybe I'm better trying that?
Old 03-20-2018, 08:24 PM   #15
kirkandorules's Avatar
My understanding is that mixing coolant types was a bigger deal back when the 986 was a new car, and there were multiple (and not necessarily compatible) formulas out there. Now, they're mostly the same. But if your coolant is original, it's probably time for a flush anyway.
'99 986 Ocean Blue Metallic
'87 924S, winter beater
'17 VW Golf Sportwagen, for when I need extra seats
kirkandorules is offline   Reply With Quote
Old 03-20-2018, 09:16 PM   #16
BirdDog's Avatar
The Porsche coolant (pink stuff) is uncut - you need to mix it with an equal quantity of (preferably distilled) water before putting it in your car. With that in mind, it's really not that expensive compared to Prestone and others (last time I checked they were selling Prestone as a pre-cut 50/50 mix)...
DexCool... if you use it, be sure to flush the stock coolant out (preferably flush it twice!) and change it when you get about 100,000 miles on it. After that you risk it turning into a thick gel...
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 03-20-2018, 09:18 PM   #17
Motorist & Coffee Drinker
78F350's Avatar
Here you go
(Honestly, I coudn't stand to watch enough of the video to learn the answer...)
Old 03-20-2018, 10:15 PM   #18
Not a chance I would put Dex-cool in an engine, flushed or not. As mentioned the Porsche coolant is full strength, so two to one, basically. Not that much more expensive. The bigger discussion is actually getting all of the old coolant out, and then bleeding the system properly. There are numerous nooks and crannies in the coolant system with the rads up front, just something to be aware of and keep in mind. With all the other stuff that can mess with a drivetrain, I prefer to err and the slightly more exspensive side and use the fluids designed for the engine/trans. Yeah, the Porsche stuff is unicorn blood, but it is the right stuff, and that’s never a bad thing. Most likely never replace it again, and if so, maybe once. So value wise, no issue.
Old 03-21-2018, 08:05 AM   #19
Anyone fluching and changing their coolant needs to see this....
This guy has the whole issue down to a "T". What to use and how to do it. These two vids are a must see for anyone flushing and replacing coolant. This guy seems to really have his act together.
What coolant to use:
https://www.youtube.com/watch?v=EMkoxlm6mzI
How to flush and change coolant in a Boxster:
https://www.youtube.com/watch?v=whc8e6baACw
Seems like good old plain simple Prestone is the way to go.
By the way, that idiot "Scotty" on the YouTube above has to be the most annoying creature on the face of the earth. How the heck does anyone watch him at all?
Old 03-21-2018, 09:26 AM   #20
I like Burner, but this video about coolant sure is long winded. Almost went to sleep!
2001 Boxster
