Old 03-10-2018, 08:38 AM   #3
Is the tire still on? The weight from that could be putting pressure on the bolt and making it hard to come out. Sometimes it helps to twist the bolt as you pull it out/tap it from the back.
No, tire is off. Basically the only things still connected to the carrier are the ball joint, the track arm, and the brake disc.
speedyspaghetti is offline   Reply With Quote
