Old 03-07-2018, 08:17 AM   #1
ChuckGS
Brake wear sensor
After some spirited driving the brake pad light came on. I took off all four wheels and found plenty of meat on all the brake pads. Each of the sensor wires look intact as well. So I am looking for suggestions to resolve this.
If I buy one replacement sensor can I keep moving it to different corners until the light goes out? Do I have to drive it or will the light go out just by replacing the bad sensor?
Other suggestion? Thanks
Tiga05 is offline   Reply With Quote
Old 03-07-2018, 12:17 PM   #2
edc
550 Anniversary
edc's Avatar
If you got the brakes very hot perhaps doing a lot of downhill hard braking you can melt the sensors.
Old 03-07-2018, 01:42 PM   #3
steved0x's Avatar
Light will go out when you replace the bad sensor. I melted a sensor coming down the hill into turn 10a at Road Atlanta and my brake wear light came on, got my heart rate up...
If you pull the brake pad wear sensor end out, you will probably see that one of them is melted into a blob, and that is probably the bad one, and is 99.999% one of the fronts.
I don't run any sensors anymore, I clipped about 1" from the end that connects to the wheel carrier, stripped the two wires, twisted them together and insulated them, and I just check my pads visually. Since I have the wheels off all the time due to track work and brake bleeding, it works for me
I've actually got an extra sensor I can send you if you PM me your address. IF I can find it... It was only $5 or so from R O C K A U T O . C O M.
Old 03-07-2018, 07:31 PM   #4
This is what a melted brake sensor looks like...
Old 03-07-2018, 07:42 PM   #5
AZ986S's Avatar
What Steve said. I've jumpered mine since it became an annoyance for me.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 03-08-2018, 08:43 AM   #6
x3 on shorting out... best solution by far
Good luck
"Cool Prius!"
- Nobody
