Old 02-27-2018, 11:51 AM   #1
Missing Hard Top Trim
I moved recently and re-installed the hard top to avoid any potential damage. I just happened to look at the mounting point beside the dome light and it looks like I might be missing some trim. There are four holes in the picture which may or may not be used to secure the trim. Is this normal or am I missing a trim piece?
alynch is offline   Reply With Quote
Old 02-27-2018, 11:59 AM   #2
Porsche9's Avatar
You need the hardtop latch cover. Any good Porsche dealer or Porsche parts dealer can get this part for you for about $30.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 02-27-2018, 12:59 PM   #3
There Is No Substitute.
rick3000's Avatar
The Part Number is: 986 563 551 00, price right now seems to be around $20.
Old 02-27-2018, 02:12 PM   #4
Thanks Porsche9 and Rick3000. New cover on order!
Old 02-28-2018, 03:32 AM   #5
I have to ask because I don't know the answer and mine is missing also . Does the cover snap in place ? Then un-snap to activate the latch ? Just wondering how many times can you go through that procedure before the plastic breaks ? Or is it a pain to install/remove ? Just trying to learn if it's worth it for me to order the cover , I'm also missing the rear latch covers . I bought the top used but there must be a reason they are missing . Sorry if I hijacked the original thread .
rfuerst911sc is online now   Reply With Quote
Old 02-28-2018, 07:53 AM   #6
rick3000's Avatar
It snaps in place. The plastic that is part of the top is much stronger than the plastic tabs on the covers, so the covers will break first. I have installed/removed mine at least two dozen times over the last ten years with no issue other than some of the tabs on the cover bending, and I just bent them back. I may have replaced the latch cover once in that time, but I cannot recall. You can buy the rear covers as well, check the parts manual pdf for the part numbers. They are simply a cosmetic item.
Old 02-28-2018, 08:42 AM   #7
Porsche9's Avatar
Been using mine for years and it’s still in great shape. This piece cleans up the interior nicely and in my opinion worth it. Positive is they are cheap enough that if it does break just buy another.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 02-28-2018, 09:07 AM   #8
Probably the prior owner of your hardtop took them off to adjust the fit and either forgot to replace them or broke them taking them out - although those snap in and out easily too.
Old 02-28-2018, 10:09 AM   #9
DarkStar's Avatar
Damn 30 Bucks? I've needed one since I got my top, I also need both side pieces now cause mine have broken tabs Couldn't find a part number anywhere.
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
DarkStar is offline   Reply With Quote
Old 02-28-2018, 10:17 AM   #10
rick3000's Avatar
Side Covers Part Numbers:
Left - 986 563 553 00
Right - 986 563 554 00
Old 02-28-2018, 05:50 PM   #11
1997 Tip, 2018 Macan
rexcramer's Avatar
Cover Installed
Old 03-02-2018, 09:55 AM   #12
lkchris's Avatar
Or if you want to pay more, buy one on eBay!
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
