Old 01-18-2018, 06:44 PM   #3
Beginner
Jamesp's Avatar
Originally Posted by aussieboxy View Post
Can that the power is still being applied to the motor but it has stopped moving.
Any assistance on how fault find the problem would be appreciated
Broken plastic gears in the transmissions are common and result in stalling the motor. That's what happened to me. I bought metal gears for $200 on fleabay and they did not work. They installed but the transmissions were too tight to turn easily.
Disconnect the transmission cables a the motor and if it runs, replace both transmissions.
If not you'll need a new motor.
You can get the motor or a couple of new transmissions from Woody.
Or you can just go manual.
2003 S manual
