Old 11-14-2006, 07:05 AM   #15
Originally Posted by KronixSpeed
also my porsche dealer ( i spoke with a different service advisor) says that i can get a battery pack and get power to the fuse box and open it like this. even though my battery is not in the car..i'm gonna try this route first.
Do you have access to another car so you could tap in to its battery? If not a lot of auto shops have those portable starters they will loan you maybe, otherwise a $10 car battery charger from a store should do it. In my 03 there is a special terminal in the fuse box where you attach the 12V then you attach the negative to the door hinge and you should be all set to release the trunk lid.
http://www.lawlai.com/sig.jpg
ukchris is offline   Reply With Quote
