12-12-2017, 09:32 AM
#1
1998 Boxster Silver/Red
Originally Posted by The Radium King
sometimes i wonder why i bother to reply to posts ...
This "sometimes"... how often is that? Were you being facetious?
You've ~2,000 posts to your credit. Obviously you've answered every imaginable inquiry. However, aside from sharing with me that the tube provides vacuum... actually, there is no aside. Me thinks that in those ~2,000 posts of yours lies the answer to my inquiry:
What purpose does that vacuum serve on the 98 Boxster? Further, to further massage your intellect, what changed after 1999 that rendered that line absent? What method did Porsche employ in later models to achieve the same result enjoyed on the 97/98/98 models? What was the workaround?
12-13-2017, 10:01 AM
#2
Did I stump the pros? Nothing?
1998 Porsche Boxster
12-13-2017, 12:41 PM
#3
Don't think the juice will be worth the squeeze...
But if it makes you happy then go for it!
Good luck
"Cool Prius!" - Nobody
12-13-2017, 01:50 PM
#4
Vacuum is commonly used as a switching mechanism vs. relays and solenoids.
Further, to further massage your intellect, ...
None of us are here to "massage our intellect". We're here to share our knowledge and passion for Boxster's.
...what changed after 1999 that rendered that line absent? What method did Porsche employ in later models to achieve the same result enjoyed on the 97/98/98 models? What was the workaround?
There wasn't much point in responding to these rhetorical questions. Your question was answered - you'll need to find a way for the Pedro exhaust to provide vacuum to the Tip transmission.
12-13-2017, 02:21 PM
#5
Thank you for the response. That would explain something I read along the lines of at a certain point a valve opens/closes, associated with the throttle.
With all due respect, I employed the 'massage the intellect' as my choice of words because it appeared that no one was responding to the original actual inquiry. It appeared that no one had an answer to my inquiry(s). In the future I'll tone down the vernacular to mitigate misconceptions, and to provide balance.
My other questions weren't rhetorical. I'm quite curious, now having been bitten by the Porsche bug. I've an eye on future Porsches, and for something that might seem innocuous, that vacuum line for example, I'm interested in learning about the progression. The improvement. That would be a general discussion and, last I checked, this is the forum for it. The BMWs I mastered the same way, and it was learning from people with many, many posts and lots of bruised-knuckle experience. People like you, likely. So, thank you.
12-16-2017, 04:51 AM
#6
If it doesn't do anything other than increase noise, why bother? Do you want your Porsche to sound like a ricer with a cheap CAI?
There are mods that will improve your car's performance that are easy and (relatively) cheap, like an under drive pulley or a spin on oil filter kit. Or even a magnetic drain plug.
"Cool Prius!"
- Nobody
You haven't seen my Prius.
2001 Boxster
2007 Toyota Highlander
12-16-2017, 05:08 AM
#7
550 Anniversary
"Cool Prius!"
- Nobody
How many extra bhp does the magnetic drain plug give?
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
12-17-2017, 04:47 AM
#8
At least 15.
2001 Boxster
12-16-2017, 06:03 AM
#9
"Cool Prius!"
- Nobody
Yes. A ricer. I'm looking at fart-can pipes on eBay, too. 2 footers straight out the back, 6 inch cans. 26HP gain.
That under-drive pulley I've looked at... but read somewhere that there's a small piece that has to be ground down in order for that pulley to fit. Is that correct? I've the pulley on my Pelican wishlist... but have held of purchasing it until I know it'll just bolt on... no extra shimming.
The spin on filter in on that list, too.
AOS is next on the list of parts I'm hoarding, for in the spring I'll replace the AOS, plugs, tubes, water pump, thermostat, etc.
Cheers!
12-16-2017, 02:38 PM
#10
Yes, a portion of the boss on the engine case needs to be ground down a bit in order to install the under drive pulley. Full removal of the boss isn't recommended as the boss might need to be used at a later date to hold the engine at TDC for repairs.
The installation recommendation is to only remove enough of the boss to clear the UDP while still retaining enough of the boss for future use.
This thread has relevant information and discussion. Do a search on "under drive pulley" and you'll find that this subject has been well discussed.
Installed the raby under-drive pulley
12-17-2017, 05:15 AM
#11
Thank you. Read the material... the boss... makes sense.
Cheers.
12-16-2017, 10:20 AM
#12
"Cool Prius!"
- Nobody
