Old 12-08-2017, 04:01 AM   #1
Spacers for 18" Carrera Lights
I have a 2004 Boxster with 18" Carrera Lights with what look like 5mm spacers both front and back. What size spacers can I put without rubbing? My mechanic says my car is slightly lowered with Porsche's lowering springs which I believe is only about 10mm, but I'm not exactly sure.
I was thinking of doing 15mm front and 25mm rear. Anyone have experience with this?
FRONT: 7.5x18 (ET 50) 225/40ZR18 +5mm spacers
REAR: 9x18 (ET52) 265/35ZR18 +5mm spacers
dchutinaton is offline   Reply With Quote
Old 12-08-2017, 05:01 AM   #2
1998 Boxster Silver/Red
Originally Posted by dchutinaton View Post
I think 25 and 15 would be too much. Maybe 20 rear... 10 front? Too far out and it looks ricer.
Old 12-08-2017, 05:04 AM   #3
Artist, 986S tinkerer
NewArt's Avatar
You can use the calculator at wheel-size.com to try out various scenarios.
Old 12-08-2017, 07:50 AM   #4
Thanks for the replies. I'm kinda new to this whole spacer for aesthetics thing. Not sure how far out looks good on a Boxster and also not sure if I go too far out and it would cause the wheel to rub. I've also heard of people going with 7mm in front and 15mm in the rear. Anyone tried adding spacers using these same wheels?
Old 12-08-2017, 09:48 AM   #5
I have 9" rears with stock offset of 50 and use 12mm spacers and I only think I can go 2-3mm more and be inside the well.
A 25mm spacer will move them out 15mm more than stock
Old 12-08-2017, 11:19 AM   #6
FWIW I did the 23mm spacers in the rear, but I have the 18x10 carrera lights which are ET65
98 Arena Red 986
Old 12-08-2017, 12:55 PM   #7
I think you'll find that 15mm all the way around will work well and really fill out the wheel wells.
deathsled986 is offline   Reply With Quote
Old 12-09-2017, 05:19 AM   #8
Thanks for the responses. I think I'll try 15mm front and rear and see how that goes.
Old 12-09-2017, 05:50 AM   #9
I went with 20 rear 10 front (98 Boxster) after reading a lot of posts. The profile from the rear is subtle, but noticeable. Maybe do some measuring to see exactly how far out would align with the look you're trying to achieve. Best wishes!
Old 01-24-2018, 10:47 AM   #10
So I picked up a set of 15mm Eibach spacers for both the front and rear of my Boxster. About to get them installed when I noticed there's an "extra" hole on each spacer in addition to the dual 5 bolt pattern. What is this "extra" hole for?
Old 01-24-2018, 11:15 AM   #11
The Radium King's Avatar
does it line up with the rotor fastener?
Old 01-24-2018, 06:15 PM   #12
I haven't tried yet to see if it lines up with the rotor fastener. If it does line up should I try to find an appropriate length bolt and fasten it to the rotor? Will using it make a significant enough difference in balance to cause vibrations?
If I recall correctly there are two rotor fasteners on my current 5mm spacers.
Old 01-24-2018, 07:41 PM   #13
husker boxster's Avatar
Doesn't everybody need extra hoes? (In case one is busy.)
1989 928 S4 5 spd - black
Old 01-24-2018, 09:35 PM   #14
rotors have two fasteners as well. don't think balance is an issue. the fasteners are not a strength thing, they are just there to keep the openings aligned for the wheel bolts.
Old 01-24-2018, 09:37 PM   #15
my understanding is that four hoes is best. one is not enough, and two will fight. if you have three then two will gang up on the third, and not many folks can afford five, so four is appropriate.
Old 01-25-2018, 03:45 AM   #16
JBauer's Avatar
15s front and rear.
Old 01-25-2018, 08:08 PM   #17
eicheldp's Avatar
Don't forget to get the extended length wheel studs.
2004 Boxster S
eicheldp is offline   Reply With Quote
Old 02-03-2018, 07:25 AM   #18
Got the 15mm spacers installed on the front and back. Looks and drives great. Not sure if I'm imagining it or not, but it feels to me like the steering wheel is a tad lighter and the springs a tad softer. Took it up to highway speeds and didn't feel any weird vibrations. The car still feels very stable at high speed in a straight line. Haven't had a chance to take it onto twisty roads so I don't know if there's a difference there.
That extra hole I was asking about on the Eibach spacers didn't line up with anything on the rotors.
I took off the 5mm spacers that were on the car. It had two tapered bolts to fasten it to the rotor. Once the 5mm spacer was removed I saw two tapered holes on the rotor that looked like they were designed just for keeping those tapered bolts. The mechanic at the tire shop suggested I put the tapered bolts there. Is that a good/bad idea? Is that what its for? Unfortunately I forgot to take a picture of the rotor with the wheels and spacers off.
