Old 01-24-2018, 08:35 PM   #14
The Radium King
The Radium King's Avatar
Originally Posted by dchutinaton View Post
I haven't tried yet to see if it lines up with the rotor fastener. If it does line up should I try to find an appropriate length bolt and fasten it to the rotor? Will using it make a significant enough difference in balance to cause vibrations?
If I recall correctly there are two rotor fasteners on my current 5mm spacers.
rotors have two fasteners as well. don't think balance is an issue. the fasteners are not a strength thing, they are just there to keep the openings aligned for the wheel bolts.
