Old 05-15-2018, 10:37 PM   #21
Damn Yankee
TeamOxford's Avatar
In retrospect, maybe the stock setup would be best?
Just sayin'..............
TO
Old 05-16-2018, 01:01 AM   #22
Cunningr's Avatar
The FVD Sound version has been getting excellent reviews, saying it has no drone but beefier sound. I do not have one yet, but you would be correct if you want 100% sure no drone then stock, but in my opinion and many other others the stock muffler is lacking.
Old 05-16-2018, 04:43 AM   #23
"50 Years of 550 Spyder"
10/10ths's Avatar
FVD Brombacher Sound Version.
Just buy one.
Old 05-16-2018, 06:49 AM   #24
98 Arctic silver 986
tommy583's Avatar
TO
Yeah I get what you're saying, but I can't seem to let well enough alone. I'm sure the stock muffler will go back on after I perform an internal bypass mod on it.
Old 05-16-2018, 10:09 PM   #25
MN 986's Avatar
Just buy one.
+1 ^
FVD Brombacher Sound Version muffler and Top Speed (or other) secondary cat delete pipes sound amazing. No drone, louder but reasonable at idle and steady highway cruising, and pure flat 6 wail at WOT/high RPM. One of my favorite mods.
MN 986 is offline   Reply With Quote
Old 05-17-2018, 06:49 AM   #26
I would love to hear a really bad drone. I have a beluga on mine and I think it drones a bit between 2700 and 3000. It's really not bad and I just think of it as the car saying "Let's dance". I am just curious if what is not bad to me is bad to others.
DWBOX2000 is online now   Reply With Quote
Old 05-17-2018, 07:17 AM   #27
For me I found that it reverberated at frequency that felt like it was vibrating my head. It just made my head sore. It's a really cheap system that obviously wasn't acoustically engineered lol. I mean just look at the thing.
Old 05-17-2018, 10:07 AM   #28
tommy583's Avatar
I think a lot of the drone was due to the fact the one of my clamps between the cat and C pipe is past it's prime. I tightened it as much as I could with a 3/8 ratchet. The drone at this point was unreal. It truly sounded like a 120 decibel pipe organ playing around 50hz was behind my head. That was with the top down, up it was even louder. Since I torqued the heck out of the clamp with a 2 foot breaker bar it's much quieter now. I'm sure I could tighten it even more, but i'm scared the bolts will break.
Either way once it gets out of the drone zone it sounds awesome. I will put the new clamps on when they arrive. If that doesn't get rid of it i'll try the baffles.
Old 05-20-2018, 06:59 PM   #29
tommy583's Avatar
OK new clamps came on Friday, so I installed them. While I had the C pipes off, I tried a baffle. On the passenger side I cut the end off one of the baffles and put it in the C pipe closest to the muffler. This cut the drone down about 75%. Today I put the other baffle in the drivers side C pipe. On this side I used the entire baffle wrapped with hi temp fiberglass. This is the way it came from Car Chemistry. This set up dropped the drone to about 99% gone. It might be too quiet now. I may open the passenger side back up and take another inch or two off that baffle. The way it is now it is basically sounding like the stock system with a crios mod at idle. WOT it is a little louder and deeper. On over run I can hear some burbles. I'll roll with it for a few weeks before i mess with it.
Old 05-22-2018, 04:29 PM   #30
Anybody tried welding a pipe to unite the mufflers?
CDNIcecube is offline   Reply With Quote
Old 06-04-2018, 06:45 PM   #31
tommy583's Avatar
I have seen a few guys try that.....they said it doesn't work, still drones.
Old 08-09-2018, 08:39 AM   #32
Who's askin'?
maytag's Avatar
This looks like the right place to post some experience with the "Beluga" mufflers, from Ebay.
In another thread, I was downright insistent that mine did not drone. As a matter of fact, I suggested that others might not know what "drone" really is.
Fast-forward 2000 miles on the unit: yeah, mine began to drone. Between about 2200 rpm and 3000 rpm. It's not horrible, and certainly not "unbearable", as some report. But who knows: maybe it continues to get worse? I don't know. But it should have occurred to me that any muffler using a "packing" of any sort to attenuate sound would experience some changes as it ages.
In the meantime, however: What HAS become unbearable to me, is the rattling from inside the mufflers.
I first noticed it within about 2 weeks of installation. When I'd start the car, I'd hear a ringing-rattle from the left can. Once warm, it would diminish, or sometimes stop. But it became progressively worse. I contacted Beluga, in Galveston TX. They confirmed they have a 1-year warranty period for defects in workmanship, but they require I send the unit back to them for inspection. I decided to live with it until winter.
BUT: it kept gettting worse and worse, and eventually the right side was doing it as well. I once stuck a length of coat-hanger wire up the can, and managed to hook it on the perforated inner-pipe. Putting just the slightest tension on it made the sound go away entirely. So eventually I ran a borescope in and took a look. Sure enough: the inner, perforated steel pipe was rattling against the outer stainless housing. My guess is that they tack-weld it in place, and the welds are insufficient. That both sides did it concerns me that it may not be an isolated event.
I removed it to send back to them, since I was down and out for abit with a bad clutch. Holding it in my hands and shaking it, before I placed it int he box, I was able to reproduce the sound enough to confirm that they will be able to understand the problem when it gets back to Beluga, tomorrow.
I have no reason to expect they won't honor the warranty. I'll keep you updated.
Old 08-09-2018, 08:55 AM   #33
steved0x's Avatar
They honored the warranty on mine, sent me a new one no hassle, after I sent the original back to them.
https://youtu.be/9t9zPeEq2jQ
Old 08-09-2018, 09:03 AM   #34
Who's askin'?
maytag's Avatar
Yup! That's the sound!
Old 08-09-2018, 06:35 PM   #35
Thanks that’s pretty much what I hear at idle. Otherwise I really enjoy the exhaust.
-1999 Boxster 3.4L swap/NHP Headers/Fabspeed maxflow/ Coilovers/GT3 arms/adj. rear toe links/Tarret front and rear bar/UIDS/UAOS
-2002 911 Turbo -JRZ RS Pro/GMG swaybars/RSS/Billet k16s/ Markski turbo inlet pipe, tune, 3” exhaust, intercoolers/GT3 seats w/red GT3 belts/CCW classics
Sveach756 is offline   Reply With Quote
Old 08-10-2018, 06:46 AM   #36
If they replace the system with the same, won't it have the defect as well? It sounds like bad assembly practices.
2001 Boxster
2007 Toyota Highlander
Old 08-10-2018, 07:03 AM   #37
Who's askin'?
maytag's Avatar
That's precisely my concern. But the warranty was for replacement only, not refund. So, if it happens again, I'll cut it open and fix it myself. Pfft.... I don't mind welding stainless.
Old 08-10-2018, 07:45 AM   #38
pilut2's Avatar
After I installed my muffler I sent Beluga an email asking about clamping suggestions to try to eliminate drone. They never responded and I gave up after a couple tries, their customer service falls a bit short. Hopefully your warranty return will go smoothly. I sold the unit to a guy who was going to track his Boxster. I don't miss it at all.
pilut2 is offline   Reply With Quote
Old 10-05-2018, 10:23 AM   #39
Beluga racing refused to warranty my exhaust rattle because the car changed hands despite having receipts and proof of purchase from March this year. They did however provide me a discount on a newer unit. I finally got around to installing it today, I was getting really tired of my boxster sounding like a tin of marbles.
It looks like they updated their exhaust design/ bought from a different manufacturer. You can see the old exhaust had a crossover vs the new exhaust which is more like fabspeed max flow mufflers with no crossover and they added a beluga name plate to one of the cans. I’m just hoping it lasts and the exhaust doesn’t drone too bad.
I do plan to take the old exhaust to a shop and see if they’re willing to replicate something similar but with larger diameter piping.
I’ll update with pictures later this forum isn’t super user friendly
Old 10-05-2018, 11:26 AM   #40
1998 Boxster Silver/Red
I'll be adding them to vendors with whom I won't do business. Sounds shady. **************** those types.
Thanks for the updates apprising of the stellar customer service.
Edit: Only four letters in the ******* above.
1998 Porsche Boxster
