Old 11-18-2017, 01:19 PM   #1
Ciao's Avatar
How to Properly Check Coolant Level?
As I store my 01S for the Winter, I double checked the oil and coolant level.
I noticed the coolant level is at the Min mark. I hadn't driven the car in a week.
My Bentley Manual is not clear on how to check the coolant level. Should it be at the MIN mark when cold? Should I add coolant to the MAX when cold or is the proper time to check the coolant after it's been driven?
Thanks!
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 11-18-2017, 02:35 PM   #2
When cold, the coolant tank level should be about midway between minimum and maximum.
Old 11-18-2017, 03:58 PM   #3
Ciao's Avatar
Great! Then I can add some coolant while in storage without worrying it is overfilled when I start it up this spring.
Thanks!
Old 11-19-2017, 08:28 AM   #4
There Is No Substitute.
rick3000's Avatar
If you add coolant or distilled water, I would recommend driving for 2 days (when you take it out of storage) with the bleeder valve open to make sure any air bubbles can escape the system.
Old 11-19-2017, 09:04 AM   #5
Ciao's Avatar
An interesting thought. Will any fluid leak out with the bleeder valve open?
Thanks!
Old 11-19-2017, 11:52 AM   #6
rick3000's Avatar
It shouldn't leak with the bleeder valve open.
