Old 11-19-2017, 11:01 AM   #1
Using some aluminum-grade anti-seize on those caliper mounting screw threads prevents this thread galling problem from happening. I've had really good luck with the aluminum paste formulation anti-seize for bolts like these - Permatex #81343 works great, and comes in an easy to use small tube which doesn't seem to evaporate, or allow the oil to separate from the solids.
Going for a light, even coating on the threads (so it looks like in the photo below) keeps things neat and tidy:
How to Properly Use Anti-Seize
2001 Boxster
Old 11-19-2017, 12:26 PM   #2
I used a very light coating of anti seize on the first few threads as that is where the problem started. Seeing as the pads were original (I think) with 110k (60k miles) I doubt I will ever change them again
ps my Motive bleeder is a wonderful tool
__________________________
'58 356A coupe, just a driver
'00 Boxster S fair weather - daily driver
'11 Jeep Grand Cherokee Limited - winter daily driver
'92 F250 - junk hauler; previous Porsches '95 993;'08 Cayman S;'70 911E
356Guy is offline   Reply With Quote
