Old 11-11-2017, 03:30 PM   #1
Ciao's Avatar
Assessing Rear Axle Rubber Boot
I was changing the oil today and noticed this in the rear axles. Is this normal? Or do the rubber boots in the rear axle need replaced? How much would it cost?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 11-11-2017, 08:25 PM   #2
still plays with cars...
BoxsterSteve's Avatar
Yeah, they’re done. Had mine replaced a couple of years back; under $400 if I remember.
I could have done it at home, but I would have had to buy $100 worth of tools I didn’t own plus the parts and spend a whole weekend getting totally filthy and greasy. Didn’t appeal to me at all.
Dropped the car off at 7:30 a.m. and my indie had it done before noon.
Six speed 2000 Boxster S
Old 11-11-2017, 08:32 PM   #3
Ciao's Avatar
Ok, there are tears on both sides inside and outside
Old 11-12-2017, 09:04 AM   #4
Artist, 986S tinkerer
NewArt's Avatar
You can certainly DIY. I have replaced the boots on 2 cars, one a tip and the other a 6 speed. The parts are cheap, it's mostly a labour intensive job. Be prepared to get dirty and make sure you have everything that you need before starting. You don't need to remove the complete axle, just the inner flange. However, if you do decide to remove the axles, it will be easier to work on.
Old 11-12-2017, 09:12 AM   #5
Ciao's Avatar
Hmmm. What do I need in terms of tools?
Old 11-12-2017, 10:12 AM   #6
mikesz's Avatar
I am in the process of replacing my inner cv joints. Outers cannot be replaced all new axle $$$$. I would say replace boots and also inner while you are in there asap!
99 Porsche Boxster
Old 11-12-2017, 01:25 PM   #7
Keith Newby's Avatar
buy the boot replacement kit...pelican I think. It has four boots, clamps and grease. It's a PIA by the way. A character building exercise.
Keith Newby is offline   Reply With Quote
Old 11-12-2017, 04:39 PM   #8
Porsche "Purist"
Paul's Avatar
deleted.....
1987 924S. 2002 996TT. PST-2
Old 11-12-2017, 08:49 PM   #9
NewArt's Avatar
socket set with extension bars. Allen or Torx socket for flange bolts, end nipper pliers or special clamp tool for the boot clamps. A c-clip pliers. Torque wrench.
Old 11-13-2017, 02:58 PM   #10
1999 base
Meir's Avatar
and if you decide to remove the axle from the car and work on the bench, you will need a 32mm socket and a big ass torque wrench.
ho. and you will need to buy a new nut as well.
Old 11-13-2017, 06:56 PM   #11
Ciao's Avatar
Got that, except for a new nut
