Old 11-03-2017, 06:18 PM   #1
The Radium King's Avatar
wheel studs
so, here is a question. i currently have press-in studs on the front of my car. they are not long enough for the amount of spacer i want to run and i want to replace them with longer ones.
so, once you have pressed-in a stud, are the threads ruined forever after so that i cannot replace them with screw-in studs?
bonus question - possible to get press-in studs out without removing the hub?
thanks.
Old 11-04-2017, 05:25 AM   #2
jsceash's Avatar
I doubt that you can install a threaded stud after using a press in stud The ridges would destroy the threads. However longer press in studs are a possibility. I haven't looked at the bearing holder and hub recently, but I thought there was a spot where there was enough clearance to press a stud out. You might try a clamping ball joint tool to press out the old stud.
You could also try a puller like this one to run the nut on the new stud to pull the new stud into the hub.
Old 11-04-2017, 07:32 AM   #3
edc
550 Anniversary
edc's Avatar
Is a helicoil or timesert possible?
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
Old 11-04-2017, 09:30 AM   #4
Hmm, using helicoils on a hub does not sound like a very safe idea, hopefully someone more knowledgeable than myself will pitch in..
PS: perhaps getting a couple of used hubs from Woody may be a safer option.
Old 11-04-2017, 10:27 AM   #5
Pirate50's Avatar
Couldn't you use these type of spacers?
2004 986 Basalt Black Metallic. L&N IMS Retrofit, 996 Door Cards, Smarttop, Aerokit II bumper and sideskirts, Toth ducktail
Pirate50 is offline   Reply With Quote
Old 11-04-2017, 10:36 AM   #6
Racer Boy
Racer Boy's Avatar
I agree, that is not a good idea. Keeping the wheels on the car is probably the number one thing to worry about.
Old 11-04-2017, 11:11 AM   #7
that’s a good idea. lots of weight, though, all spinning around. i had a look last night and it should be possible to remove the current press-in studs and fit some longer ones without pulling the hubs. or wait and put some new hubs in when i do the bearings (they are about due anyway).
