Thread: wheel studs
Old 11-04-2017, 06:25 AM   #2
jsceash
jsceash's Avatar
I doubt that you can install a threaded stud after using a press in stud The ridges would destroy the threads. However longer press in studs are a possibility. I haven't looked at the bearing holder and hub recently, but I thought there was a spot where there was enough clearance to press a stud out. You might try a clamping ball joint tool to press out the old stud.
You could also try a puller like this one to run the nut on the new stud to pull the new stud into the hub.
