10-24-2017, 10:10 AM
#21
Originally Posted by GTA_G20
Personally I:
-Inflate to 50 psi
-park each tire on styrofoam squares
Carpet may work but def not concrete
Suspension should remain compressed not suspended. Do not leave your car on jack stands when winterizing
+1 and a tarp...wrapped up over wheels and exhaust
986 00S
10-24-2017, 05:41 PM
#22
Toppy
I found a 1” rubber 12x12 patio stone, one under each tire, better than right on the concrete for 5 months
1999 Boxster
Arena Red/Graphite Grey Interior/Black 03 Top/550 All Red Tail Lights
10-25-2017, 05:07 AM
#23
"50 Years of 550 Spyder"
Ciao.....
...Actually, no. I hate to admit this, but I bought these:
Welcome to LDB Auto Performance Inc. - We Know Why You Drive!!!
They are stupid expensive.
I have a unique parking situation for my car and this solution helps me with precision parking and Flat spot prevention at the same time.
I honestly can’t tell if they make a difference or not.
I live down south and drive all year long, so my car never sits longer than three weeks.
I think the carpet solution is as good as any.
Just air up the tires and don’t worry about it.
More important is to fill the tank completely with a non enthanol fuel and put some Sta-Bil in the tank and don’t fire up the engine for less than fifteen minutes at a time so you don’t contaminate the oil.
And plug a battery tender into your cigarette lighter and use the factory cutout in the door weatherstripping to route the cable.
Cheers!
10-28-2017, 08:00 PM
#24
I inflate to 55-60 psi and park on top of plywood sheets to insulate from the concrete. Plastic sheeting underneath the car. Sta-Bil in the tank before topping off. Battery tender, desiccant packs in the interior, plastic bags rubber-banded around the tail pipes, containers of mothballs at strategic points around the exterior to keep varmints away, and a cover.
DBear
10-29-2017, 05:34 AM
#25
DBear
Plywood sheets between tires and concrete is a new idea I can consider. Coming from Wisconsin the weather in Colorado is comparable.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
10-29-2017, 10:13 AM
#26
Hi everyone, why not disconnect the battery and trickle charge once a month (986 2002) versus battery maintainer full time?
Thx.
10-29-2017, 10:31 AM
#27
Because...
...a high quality battery maintainer device also "conditions" the battery so it lives longer.
10-29-2017, 11:49 AM
#28
Thx.
The major reason for buying a quality maintainer rather than a cheap trickle charger is that the electronics in a good maintainer run a desulfurization step in the charge cycle, and then keep the battery in top condition by simply letting it do its job. We store cars for customers and use only Ctek units for this reason. And these cars sit on their maintainers for months on end without any problem. We have had cars sit like this for as much as 2 years with no ill effects.
The cheap trickle charger continuously cooks the battery, actually shortening its life. In maintainers, you get what you pay for, period.
11-10-2017, 09:12 AM
#30
I've had the car stored longer that just a winter over the last 10 yrs and all you need to do is raise pressure to 45-50 psi. Flat spots will smooth out after several miles of driving when you bring pressure back down.
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
11-10-2017, 09:32 AM
#31
I'm rising the pressure to 50 PSI and let it sleep for 6 months....
2003 Boxster base
Upgrades so far: 4 Stalks installed,OBC, Cruise Control, Variable wipers, Rear speakers, Alpine CDEHD149BT deck, Alpine MRP-F250 4 ch. amplifier, Blaupunkt THb 200A pre-amplified subwoofer, XM radio integration, 997 shifter, front motor mount, LN Engineering IMS upgrade and much more.
11-11-2017, 07:40 AM
#32
Set tire pressure to 60 psi and put wheels on styrofoam
Excellent results with 4 styrofoam plates 1.5 in thick during winter sleep.
Prior to roll the Boxster onto the plates I pump the tires to 60 psi.
When starting up in spring, reduce the pressure back to normal and you will drive away with perfectly "round" wheels.
11-11-2017, 09:37 AM
#33
Best Cost Effective solution seen!
11-11-2017, 11:46 AM
#34
Bently owners manual says to inflate all tires to 50 psi if car will be parked more than a week.
| Thread Tools |
| Display Modes |
Linear Mode
