Old 10-29-2017, 05:34 AM   #25
Ciao
Ciao's Avatar
Originally Posted by dbear61 View Post
I inflate to 55-60 psi and park on top of plywood sheets to insulate from the concrete. Plastic sheeting underneath the car. Sta-Bil in the tank before topping off. Battery tender, desiccant packs in the interior, plastic bags rubber-banded around the tail pipes, containers of mothballs at strategic points around the exterior to keep varmints away, and a cover.
DBear
Plywood sheets between tires and concrete is a new idea I can consider. Coming from Wisconsin the weather in Colorado is comparable.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
