Old 11-04-2017, 03:32 PM   #1
Thanks i will try that Sunday .
mebeached is offline   Reply With Quote
Old 11-05-2017, 08:06 AM   #2
Hello Particalwave I have completed the test . Step # 3 and the red with /blk stripe only had 5.75 volts on it opened passenger side and no voltage on red and /blk wire.
Closed passenger side door and opened it a couple times still nothing.
I went back and opened drivers side and had that 5.75 volts on the red /blk wire on the Imobilezier.
What does that tell me a short or bad Imobilezier?
Old 11-07-2017, 06:15 AM   #3
Smile door lights
Particalwave wave where did you go? does anyone know what to check if you dont have the 12 volts on this wire.
Old 11-08-2017, 05:58 AM   #4
Hello Partical wave, i checked the red wire with the bk stripe. I only had 5.75 volts. that was the wire from the Immobilizer box.
do you know where to go from this? Hope not to repair shop. I heard it cost $800 for them to repair and send back.
Old 11-09-2017, 12:19 AM   #5
If you're positive that you're getting 5.75V+ at the immobilizer and 0 at the dome light, you likely have a short to ground somewhere. I'll take a look at the wiring diagram for your '97 tomorrow and list everything on that circuit so they can all be checked.
Old 11-10-2017, 03:55 PM   #6
sounds good !
Old 11-13-2017, 11:35 AM   #7
Front and rear trunk lights (option dependent)
Top button
Rear defrost button
Seat memory buttons (M537 & M538 only)
Power mirrors
Dome and door lights
