Old 10-22-2017, 05:15 PM   #1
Has anyone ever welded a permanent extension onto the stock roll bar?
Or even made a taller replacement? Seems like a good alternative to bolting and unbolting the Brey Krause for driving events.
lskolnick is offline   Reply With Quote
Old 10-22-2017, 05:54 PM   #2
The roll bar is made from high strength steel. Welding something to it will weaken it. You should never do that!
1941 Dodge Luxury Liner Coupe
Old 10-22-2017, 06:58 PM   #3
Good to know. Has anyone ever set out to make a taller replacement option, rather than a bolt on extension?
Old 10-22-2017, 07:01 PM   #4
There Is No Substitute.
rick3000's Avatar
You have to consider the clearance needed for the soft top to be put up/down. There are more extensive roll cage setups for racing.
Old 10-22-2017, 07:38 PM   #5
steved0x's Avatar
You can't really go any higher than the BK bar, the top barely clears it, and if you don't close the latch it will touch.
Old 10-22-2017, 08:25 PM   #6
Porsche "Purist"
Paul's Avatar
What's wrong with leaving the extension on the car full time?
1987 924S. 2002 996TT. PST-2
Old 10-22-2017, 08:53 PM   #7
The Radium King's Avatar
the safety devices bolt in roll bar is taller (how do i know - my ztop won’t fit over it, but fits over the oem roll bar) and gives you the option of adding door bars, etc.
