Old 10-17-2017, 01:42 PM   #1
Ciao's Avatar
Brake Light Bulb Loose
I have a Brake Light Bulb located on the right side that fits loose on the socket of the light housing and keeps falling off. I have the original light assembly 2001 Box S. The aluminum track that runs through the housing for this bulb is loose unlike the others.
Anyone have a solution?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 10-17-2017, 02:12 PM   #2
steved0x's Avatar
Mine used to get loose and then the brake lights wouldn't work, I think I squeezed the two sides together, and I may have added a little epoxy to keep the bottom metal track in place against the plastic housing.
Old 10-17-2017, 04:42 PM   #3
Ciao's Avatar
Interesting solution; thanks, I may try this
Old 10-17-2017, 07:24 PM   #4
I secured the trace with a long screw through it and into the plastic tray.
Old 10-18-2017, 08:30 AM   #5
Ciao's Avatar
I took out the tail light assembly today for a close look and discovered the loose metal track/trace has slots that may have come loose from the plastic tray. I re-insterted the slots located at the bulb location and ensure the other slots/notches were snug into the plastic part. I also closed the bulb slot slowly/carefully (with my fingers) and the bulb fit in much secure and tighter.
This simple solution may have solved the problem of the brake light bulb coming loose.
Old 10-18-2017, 10:16 AM   #6
The trace(s) will pop back out.
They always do...
Old 10-18-2017, 10:23 AM   #7
steved0x's Avatar
They always do...
Yeah especially if you drive on bumpy roads. Since I did the epoxy it hasn't happened again.
Old 10-18-2017, 10:35 AM   #8
Ciao's Avatar
Thanks! I'll keep an eye on it; if the traces pop out again, I'll try the epoxy approach.
