Old 10-02-2017, 07:39 AM   #1
What is this hose??? and few other things
New owner 03 Boxster 5spd 72900 miles. there is no service history. I did my oil change this past saturday used Mob. 1 0w-40 took 9 qts of oil.
while had the car up on lift I checked out the engine and saw following things:
1: small oil dropping bottom of the engine where it mount to trans. Does the oil leak look like leaking from rear main seal?
2: both left & right inner axle shaft inner boot to trans. clamp is on the boot right side worse than left. I didn't see any tear on the inner boot. there is some grease that spattered on the right side front of the boot to engine. I can turn the inner boot easily with my hand again the clamp is on the boot there's some grease as you can see from the photo coming out. I shouldn't be able to turn the boot with my hand right? is inner boot clamp even though is on the boot worn and should I replace the clamp?
3: i'm guessing the top hose is coolant hose. The hose below the coolant hose looks like was leaking at some point and the leak as you can see hardended. What hose is the hose below coolant hose what can this hardened stuff be?
Thanks in advance for any input you guys can give me.
JOC IN IL is offline   Reply With Quote
