Old 08-26-2017, 12:31 PM   #1
Key repaired, still won't sync.
Purchased a 2000 Boxster S a few months ago and have been addressing some of its issues with the help of this forum. After replacing the fuse in the immobilizer I was able to lock the doors using the key. Until that, the passenger door could not be locked. Although the key transmitter would light, I was unable to sync it to the immobilizer. I sent the key's circuit board to particlewave to see if it was at fault. He replaced the two buttons and soldered some broken connections. I tried all the syncing methods I've read about. Key in ignition on, off, press button within 6 seconds. Key in door, unlock, press button. Reverse battery, press button, wait 10 seconds, reverse back. Nothing worked. Any suggestions as to what my next step should be?
Thanks,
Ric
Fodoposto is offline   Reply With Quote
Old 08-28-2017, 08:46 AM   #2
Administrator
Welcome! Sorry, your thread was stuck in moderation so just giving you a friendly bump back to the first page. Don't forget to check out our free tech articles while you work on your issue and I'm sure more community members will chime in with help for you as well. I am here if you have any parts or forum questions.
Porsche Boxster 986/987 (1997-2004) Technical Articles | Pelican Parts
Luccia at Pelican Parts is offline   Reply With Quote
Old 08-30-2017, 09:58 AM   #3
Swhitcomb's Avatar
Must be a black boxster thing. I sent him my immobilizer. He cleaned up the circuit board and tested it. Worked fine for him. I'm getting 2 error codes and it won't unlock with the 3rd party key fob.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Swhitcomb is offline   Reply With Quote
Old 08-30-2017, 11:02 AM   #4
I hooked up the durametric a couple months ago and was code free. Will need to check again. I knew this was an issue when I purchased the car. The previous owner had taken it to the dealership and spent $700 on "something in the doors." No repair invoice to check what was done. My first new car was a 1977 Toyota Celica Liftback. Waited 3 months and paid full sticker to get a black one. Still my favorite car color.
Old 08-30-2017, 02:25 PM   #5
ECU Doctors's Avatar
If 1 of the 2 doors are working then it's got to be the door's actuator, not your key fob.
Can you open both door locks from the inside cabin switch?
ECU Doctors is offline   Reply With Quote
Old 09-01-2017, 02:28 PM   #6
After replacing the fuse in the immobilizer both doors will lock using the key and the inside cabin switch.
Old 09-05-2017, 06:54 AM   #7
What! Really?
That fuse powers the entire unit. If the fuse was bad, none of the Immobilizer functions of the car should have been working. Strange.
I wasn't there to see what happened, but I can suspect that it was really a bad connection from the harness to the control unit.
While you were changing the fuse the connector "re sat" perfectly again getting everything to work properly.
Anywho...everything is working again. Good job!
Old 09-11-2017, 12:57 PM   #8
What! Really?
Thanks for your response ECU Doc. You're probably right about the connector being reseated. However, while the door locks and dash button work, the key fob still does not.
Old 09-19-2017, 02:58 PM   #9
Fodoposto,
Try opening the fob and resitting the battery to see if that's any help.
Otherwise, it may need some TLC from us to revive it.
