Old 08-26-2017, 12:31 PM   #1
Fodoposto
Key repaired, still won't sync.
Purchased a 2000 Boxster S a few months ago and have been addressing some of its issues with the help of this forum. After replacing the fuse in the immobilizer I was able to lock the doors using the key. Until that, the passenger door could not be locked. Although the key transmitter would light, I was unable to sync it to the immobilizer. I sent the key's circuit board to particlewave to see if it was at fault. He replaced the two buttons and soldered some broken connections. I tried all the syncing methods I've read about. Key in ignition on, off, press button within 6 seconds. Key in door, unlock, press button. Reverse battery, press button, wait 10 seconds, reverse back. Nothing worked. Any suggestions as to what my next step should be?
Thanks,
Ric
Fodoposto is offline   Reply With Quote
