Old 08-16-2017, 05:55 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
A couple of suggestions; push down on the lid while pushing the button, then try the reverse, gently pulling up while pushing the button. If there is a bunch of stuff jammed in there, it might be loading the latch. I wonder if you pull the ash tray if you can some access and or put a camera probe into the cavity?
