Old 07-28-2017, 06:46 AM   #1
flouese's Avatar
Sticking Clutch Pedal
This is an ongoing issue with my 99 base: If I keep my clutch pedal depressed for any length of time, it does not return. I have to pull it back with my toe. Other than that it functions well, no problems with shifting. Slave, master cylinder problem? Slave was replaced 2 years ago. Help! This is an annoying problem.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 07-28-2017, 04:45 PM   #2
I'd check the entire system although the slave cylinder is usually the most likely suspect. Check it just to be sure (even though it was recently replaced).
If the slave checks out then take a look at the clutch return spring (also known as the clutch power spring). They have been known to fail on occasion.
If the slave and return spring are ok, then check the master cylinder. If that is ok, then you may have to drop the transmission.
#9 in the diagram.
