Old 07-08-2017, 03:04 PM   #1
Trunk and frunk release on 2004 Boxster S
So here's a mystery and a concern:
Not long ago the trunk open knob stopped working on both of our keys. Both keys light up when the key is pressed, so it must be something in the car that's a problem. But the switch in the drivers door sill still works.
Then today at the PCA NER AX the frunk suddenly refused to open when the door sill switch was pulled, but fortunately it came back, otherwise we would have had to call my wife to come out with her car to take some of the stuff we had brought to the AX.
When I checked the parts listing it looks like the 2003 and 2004 Boxsters don't have emergency cable releases. And all the owners manual mentions is putting an external battery but still using the sill switches.
So here are my questions:
Have any of you experienced these problems and how did you deal with them?
Am I correct that there isn't an emergency cable release?
How do I get the trunk and frunk lids opened if the switches and keys fobs don't work?
This is scary, because it could have happened on the vacation we just returned from to the Canadian Maritime Provinces.
Any help will be greatly appreciated!
1941 Dodge Luxury Liner Coupe
Old 07-08-2017, 04:44 PM   #2
Multi-Boxer Driver
Deserion's Avatar
The '04 does have a release cable.
It's possible the actuator in the frunk has gone - mine did this and worked normally again once I replaced it.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 07-08-2017, 04:56 PM   #3
Thanks Chris. Good to know that there is a manual cable release. OK that it hard to get at. I'm going to use electrical contact cleaner and lubrication to see if I can make it work reliably and replace the actuator if that fails.
Old 07-08-2017, 07:21 PM   #4
I had a similar problem and it was one of my keys. It was unlocking the door, but not the frunk. I was able to clear it using my spare key. I believe your car does have emergency release cables. On the front and rear you have to pull back the fender insulation. Not sure thats what it is called but turn the front wheels to get some room, remove the pop outs and pull back the plastic on drivers side, up
Close to the bumper. The cable can be reached Same sort of thing in rear, same side of car. Before doing all that though, use your key to manually lock then unlock the car and see if that resolves the problem.
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
Old 07-08-2017, 07:27 PM   #5
Just remembered. Fender liners
