Old 06-30-2017, 05:45 PM   #1
Repair estimate - window that won't crack, turn signal issues
Hi. Anyone have any quick input on what might be the tab? Blinker works, but doesn't stay on (so needs to be held up for a turn); one window doesn't do that small drop it's supposed to when opening door.
looking at a car that has those issues, wondering what i might have to invest to get them fixed.
thanks!
bmsamson is offline   Reply With Quote
Old 06-30-2017, 06:00 PM   #2
still plays with cars...
BoxsterSteve's Avatar
Clock spring is done... can be repaired DIY
Micro switch on the affected door is pooched, also DIY, you could get a repair estimate for the jobs at a mechanic and use it as a bargaining chip if you're so inclined.
Six speed 2000 Boxster S
Old 06-30-2017, 06:00 PM   #3
Can you do the work yourself or will you have to take the car to a local mechanic?
Old 06-30-2017, 06:09 PM   #4
no time to check with a mechanic, that's why i'm asking you all, in case someone's had either/both jobs done recently.
yes, probably i could DIM, but won't get as much off the ask that way
Old 06-30-2017, 06:50 PM   #5
Multi-Boxer Driver
Deserion's Avatar
Window drop could also be a regulator with too much slack in the cable. Any noise when you open the door?
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 06-30-2017, 09:03 PM   #6
Turn signal stalk assembly = $300
Window regulator = $50
2-3 hours labor @ $150/hr = $300-$450
$650-$800
Old 06-30-2017, 09:20 PM   #7
Thanks! Just the kind of info I was looking for
Old 06-30-2017, 10:02 PM   #8
The clock spring is part of the airbag. The turn signal needs replaced. It is not an easy job. Window is the assembly with the micro switch. Again not an easy job. Both can be done if you work on your car and are mechanically inclined. You will need to purchase a few tools to accomplish both so you may want to take it to your mechanic for an estimate and then price out the parts, tools and time to do yourself. I replaced my inside door handle assembly. What would take my mechanic about an hour took me 4 hours so take that into consideration. Good luck!
Sent from my SAMSUNG-SM-N920A using Tapatalk
mmassey0125 is offline   Reply With Quote
Old 07-01-2017, 10:24 AM   #9
BirdDog's Avatar
$650-$800
Adding to what ParticleWave wrote...
If you want to fix the turn signal switch yourself, the procedure is described in detail in the 101 Projects Book (written by the founder of Pelican Parts) or can be found on the Pelican Parts website (click on "How-to Articles" at the top of the page). It's described in the article for adding the On Board Computer (OBC) and probably the article for adding cruise control.
Porsche Boxster On Board Computer (OBC) Upgrade and Turn Signal Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Be sure to read the "Thinking of buying a Boxster MUST READ" thread...
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 07-01-2017, 07:11 PM   #10
1997 Tip, 2018 Macan
rexcramer's Avatar
I bought a regulator in January 2017 and installed it DIY. The OEM part from the dealer was +/- $270 after my PCA discount.
