05-29-2017, 10:53 AM
#1
G2 caliper paint results
05-29-2017, 01:59 PM
#2
Love the G2 caliper brush on paint, I've used it several times. Nice job. Now just order some decals up from eBay and you're done!
1995 Porsche C4 Cab
05-29-2017, 09:52 PM
#3
Love the chrome twist wheels
How much prep work did you do here ??
I need to do this badly
05-30-2017, 05:48 AM
#4
Looks good! Where did you source the G2 paint?
05-31-2017, 07:17 PM
#5
Not a whole lot of prep...just a wirebrush then some sandpaper. It's not perfect but you have to be a foot or two away to see the imperfections. Nobody is inspecting my brake caliper paint job!
I bought it off Amazon...this is the RED version. https://www.amazon.com/Temperature-Leveling-G2-Caliper-System/dp/B000AUMYMM
06-01-2017, 04:53 AM
#6
Originally Posted by patssle
Thanks for that - maybe a winter project
06-01-2017, 05:25 AM
#7
Por 15 makes a great brush on kit. Says 2 calipers per kit but I did all 4 and had paint left over. Very little prep needed on mine. Didn't have to disassemble anything, just masking. Paint is self leveling. Very easy job.
06-01-2017, 05:42 AM
#8
Nice - need to freshen mine up and get new decals
Traco
_________________
Older but no wiser.
2003 Boxster S, Seal Grey
06-01-2017, 11:41 PM
#9
Looks great. How many coats of G2 paint did you apply?
06-02-2017, 08:00 AM
#10
Looks great! I am a big fan of painted calipers, they add just a bit of interest to what is otherwise a fairly boring wheel. Nicely done.
06-02-2017, 01:35 PM
#11
3. Was almost good with 2. Had enough paint left for probably 5 total coats.
06-03-2017, 09:50 AM
#12
Any reports on how the brush-paint jobs hold up after a few years ? I ask because if the job starts to deteriorate after 1 year it would be a waste.
Any comparison Por 15, G2-Amazon,VHT, Duplicolor other than the useful Amazon reviews?
Avoid -Vivid wrap product which is way faster but mixed results !
06-03-2017, 10:50 AM
#13
07 Carrera S Cab
I used the G2 brush on kit like 8 yrs ago, and it still looks good. Held up great...
06-03-2017, 10:51 AM
#14
There Is No Substitute.
I can't comment on painting them, but I used DupliColor Caliper spray paint on mine about 10-11 years ago (about 70-75k miles) and they still look really good. If I recall correctly I put about 4 coats of paint, then the decals, then 2-3 coats of clear. They have held up much better and longer than I ever expected, the only problem area is some scuffs on the top of the calipers from careless rim swaps. If I could go back in time I would also avoid using harsh rim cleaner on them, I think it has dulled the finish a tiny bit, but not much.
06-03-2017, 05:16 PM
#15
G2 Product
Is this a POR product ?
I am familiar with POR as many off road folks use to stop rust and corrosion......I read it is very very tough
06-04-2017, 08:51 AM
#16
+1 on POR
I used the POR fuel tank treatment before and it is a very impressive product, however DO NOT let it touch your skin because it Will Not come off…. guess how I found out
I was not aware that POR offers bright red paint but I would definitely consider it when decide to refurbish my calipers (but I will be using large rubber gloves…lol)
