Old 05-12-2017, 04:23 PM   #1
Creaking noise from rear?
Ok, first let me say that I've found several posts about similar issues. None really answered my question.
The noise I'm hearing is what I'd describe as a creaking noise from the rear. I only hear it when taking slow, relatively sharp turns like in a parking lot.
What I'm wondering is; What are the usual suspects? Is there a surefire way to narrow down the source of the issue?
johnrhopkins is offline   Reply With Quote
Old 05-12-2017, 04:33 PM   #2
Usual suspect is the trailing arms
rlbruce64 is offline   Reply With Quote
Old 05-12-2017, 04:37 PM   #3
Not for creaking when turning. Sounds more like dry shock absorbers.
Try pushing down on the fenders and see if you can reproduce the noise. You may need a friend to get enough force.
1941 Dodge Luxury Liner Coupe
Old 05-12-2017, 08:03 PM   #4
New Bilstein B6's will solve that issue :-P
SteelStroke is offline   Reply With Quote
Old 05-12-2017, 08:09 PM   #5
I was looking at those as a possible solution.
Old 07-14-2017, 09:22 AM   #6
I've been out of town a LOT lately. I finally got a chance to take it to my mechanic before I bought new shocks. He said with a great degree of certainty that the noise was coming from the ball joint on the passenger side. So, I've ordered a new set of lower control arms. I'll post back with the outcome after I get them installed.
Old 07-26-2017, 01:21 PM   #7
The verdict is in. The issue was the ball joint in the rear passenger lower control arm. Once we got it out we found that it was completely seized. We went ahead and replaced both the rear LCAs and noted that the boot on the left side was torn... so, I'm glad we replaced both.
Old 07-26-2017, 04:13 PM   #8
BTW, folks, pushing down on the fenders can dent the fenders.
My solution is a lot more fun. I get the wife to stand in the frunk or trunk and jump up and down while I inspect by the side of the car. Even if I don't find the source of the squeak it was worth it.
Old 07-26-2017, 04:23 PM   #9
Haha! Yes, we did try that. It was entertaining, to say the least.
Old 09-06-2017, 08:12 PM   #10
Any updates about this? Did you replace the old shocks with Bilstein or have you found another issue?
Neeno is offline   Reply With Quote
Old 09-07-2017, 11:10 AM   #11
Dang, I thought I had posted the outcome here already. Sorry about that.
So, the culprit was the ball joint on the passenger side lower control arm. I replaced both LCAs and the noises are mostly gone. I'm just now starting to hear a similar but very faint sound. I'll be checking the other ball joints soon.
