Old 05-10-2017, 06:38 AM   #1
Error Code P0446
Anyone have any info on the error code in this pic?
rlbruce64 is offline   Reply With Quote
Old 05-10-2017, 07:28 AM   #2
Chuck W.'s Avatar
I did a quick search and came up with a number of results. Tom Stones look like a good one;
Error Code, Need Help!
Here is the search result link for "P0446".
http://986forum.com/forums/search.php?searchid=2931907
And, welcome to the 986 Forum!
1995 Porsche C4 Cab
Old 05-10-2017, 08:33 AM   #3
A code P0446 could mean one or more of the following has happened: Faulty vent valve Open, short or excessive resistance on Vent valve control circuit Blockage of vent valve Bad PCM Possible Solutions With a P0446 OBD-II trouble code, here are some things to try: Replace Vent valve Repair open, short, or resistance problem in control circuit Repair open, or short, or resistance problem in power circuit Replace PCM
Read more at:****https://www.obd-codes.com/p0446
Copyright OBD-Codes.com
Sent from my SAMSUNG-SM-N920A using Tapatalk
mmassey0125 is offline   Reply With Quote
Old 05-10-2017, 09:13 AM   #4
Pelican cover this with so great photos and diy.
